Stainless steel water tank
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by CoBackCountry, May 9, 2016.
  1. May 9, 2016 at 12:08 PM
    CoBackCountry
    CoBackCountry [OP] Well-Known Member
    J
    Colorado
    Stainless steel water tank I had custom built that fits in a spare tire location under the bed on a 2nd gen tacoma, it hoists and lowers using the same system to hoist and lower the spare tire. It is roughly the size of a 32" tire, only filled it once and I forget the gallon capacity of this tank although I do believe it is 10+ gallons. Not willing to ship, located in Manitou Springs, Co. Taking a huge loss on this, asking $340. Willing to bring it out to RT for someone who wants to purchase it.
  2. May 9, 2016 at 12:13 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    How heavy is it, empty?
  3. May 9, 2016 at 12:14 PM
    CoBackCountry
    J
    Colorado
    I can't remember an exact weight, and I don't have a scale to weigh it but I believe it is right around 40lbs dry.
  4. May 9, 2016 at 12:19 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    With water being around 8 lbs per gallon, that brings the total weight of the container filled to around 120 lbs.
    Would the spare tire system be able to handle that weight?
  5. May 9, 2016 at 12:21 PM
    CoBackCountry
    J
    Colorado
    I would say yes, although I never had it fully filled plus had a huge tire strap around it to help keep it in place. I know there are plenty of guys who put a 33" tire in that location, somewhat close to that weight.
  6. May 9, 2016 at 12:28 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Any chance of seeing where the water spigot is located, and how it seals?
    Can it be filled and emptied while in the location of the spare tire?
  7. May 9, 2016 at 12:35 PM
    CoBackCountry
    J
    Colorado
    I was wrong, someone did the math for me and it holds 18.75 gallons. There is no spigot, basically just nipples so you can connect lines to it to fill and empty. The way I had it positioned under the bed I was able to fill it while it was in place, it just emptied via gravity.
  8. May 9, 2016 at 3:23 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    This is a neat idea.
    yonah and CoBackCountry[OP] like this.
  9. May 9, 2016 at 4:19 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Exceptionally cool idea!!!
  10. May 12, 2016 at 8:13 PM
    Pigpen
    Dan
    Northwest Montana
    This is pretty awesome. GLWS
    CoBackCountry[OP] likes this.
  11. May 25, 2016 at 9:36 AM
    the dashing ham
    the dashing ham Taco n00b
    Scotty
    Los Angeles
    '12 DCLB rattle can
    yes, I have done the mods
    Is this still available? I love this idea; I always wanted to put a gas can in the spare tire location.
  12. May 25, 2016 at 10:56 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I wouldn't want to trust the cable spare tire holder when full of water. I would want to use the later model spare holder that used a chain...........Just FYI, because I was gonna swap mine for chain unit..........The mounting holes are different and the chain one would require 2 new holes on the support member and use bolt/nut on those 2. And for anyone buying this that doesn't have a chain lifter, I do, with oem spare lock. If interested in swapping from cable to chain, PM me. It is in brand new shape.............GLWS
  13. May 25, 2016 at 11:58 AM
    CoBackCountry
    J
    Colorado
    Yes, still available. Could bring to RT if anyone is interested in it.
