Staking Nuts vs Impact
Discussion in '1st Gen. Tacomas (1995-2004)' started by phunky_monk, Oct 1, 2024.
  1. Oct 1, 2024 at 9:17 AM
    phunky_monk
    phunky_monk [OP] Member
    2001 V6 Tacoma PreRunner
    Hello All.
    In doing research for some various repairs I want to DIY, I occasional encounter this process of "staking a nut".
    Does using a powered impact wrench eliminate need for staking the nut? What is the point of staking in the first place?
  2. Oct 1, 2024 at 9:21 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Staking a nut is a way of preventing it from vibrating loose. You should never use an impact wrench to snug down fasteners/nuts.
    wilcam47 and SH10151 like this.
  3. Oct 1, 2024 at 10:00 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    This isn't the 'right' way to do things, but when removing a staked nut, a high power impact wrench does eliminate the need to un-stake the nut. The impact will just zip it off.
    The 'right' way would be to unstake the nut before removal.
    During reassembly though, you should not be using an impact wrench, you should get it snug and then switch to a torque wrench, and then re-stake the nut to prevent it from coming loose.
    SR-71A and wilcam47 like this.
  4. Oct 1, 2024 at 10:08 AM
    Bishop84
    Bishop84 Well-Known Member
    I dont think tacoma has any staked nuts, typically Toyota just uses on the car axle nuts. Tacoma uses cotter pins.
    Tight and torqued is all that matters, stake only when needed.
    RustyGreen likes this.
  5. Oct 1, 2024 at 10:16 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I can think of a few staked nuts on a 1st gen tacoma- the first (and probably the one that the OP is asking about) that comes to mind is in the drive shaft to hold the carrier bearing on.
    phunky_monk[OP] likes this.
  6. Oct 1, 2024 at 10:25 AM
    Bishop84
    ooooh ya, I think all the yokes have that
  7. Oct 1, 2024 at 11:02 AM
    phunky_monk
    You read my mind.
  8. Oct 1, 2024 at 11:10 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    SR-71A likes this.
  9. Oct 1, 2024 at 11:10 AM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Front bearings on manual locking hubs have staked nuts
  10. Oct 1, 2024 at 11:19 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    This.
    Also, staked nuts are technically only single use items
    time623[QUOTED] likes this.
  11. Oct 1, 2024 at 12:58 PM
    phunky_monk
    How do you unstake? Isn't staking just banging the thing with a punch and a mallet?
  12. Oct 1, 2024 at 1:01 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    un-staking is just banging the thing with a punch and a mallet the other way
    time623 likes this.
  13. Oct 1, 2024 at 1:25 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I use a impact gun when removing staked nuts
  14. Oct 1, 2024 at 1:26 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    oh, now you tell me!!
