Stall feeling when turning to the right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomatosis04, Oct 19, 2012.
  1. Oct 19, 2012 at 12:38 PM
    Tacomatosis04
    Tacomatosis04 [OP] Member
    Tony
    Flagstaff, AZ
    08 Tacoma
    I just got my truck back from getting an alignment, just installed Bilstein 5100's set to 2.5 inch with OME 886. After getting my truck back I noticed that everytime when I took a right turn my truck would accelerate normally and then mid way through the turn it'd feel like it would die while I still had my foot on the gas and then it would finally kick in. Not sure exactly what is going on but it seems sketch.
  2. Oct 19, 2012 at 12:39 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    3 lefts make a right so do that until you figure it out :D
    In all seriousness adding a lift should in NO WAY effect your throttle. Have you double checked everything?
  3. Oct 19, 2012 at 12:41 PM
    Tacomatosis04
    Tony
    Flagstaff, AZ
    08 Tacoma
    Looked at everything and it seems fine. I'm thinking it has something to do with the fuel line but not sure why it would only do it for when I'm turning right
  4. Oct 19, 2012 at 2:21 PM
    XXXX
    sKiP
    05 Prius
    truck is fuel injected so turning should have no impact on speed.
    truck is an 08' so no VSC right?
    is it throwing any codes?
  5. Oct 19, 2012 at 2:40 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sounds like the VSC
  6. Oct 19, 2012 at 2:41 PM
    XXXX
    sKiP
    05 Prius
    they have that on 08's? mine doesn't... was it an option?
  7. Oct 19, 2012 at 3:15 PM
    Tacomatosis04
    Tony
    Flagstaff, AZ
    08 Tacoma
    I don't have the VSC option on my truck
    And yes it's an 08
  8. Oct 19, 2012 at 3:46 PM
    OZ-T
    Peter North
    British Columbia
    Was an option
  9. Oct 19, 2012 at 5:10 PM
    XXXX
    sKiP
    05 Prius
    free bump
    glad I didn't get that crap on my truck...
