Stalling issues 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mcmudflap, Jan 22, 2024.
  1. Jan 22, 2024 at 3:33 AM
    Mcmudflap
    Mcmudflap [OP] Member
    Scott
    220+ 2nd gen 4.0
    Hello all,new to the board,I have an 06 4.0 manual with 220+ on it,month or so ago it started stalling when I let off the throttle, at about 4k rpm, stays running aroundnd 5 or 6 k rpm. no codes,replaced maf,deleted cats,any help is appreciated
  2. Jan 22, 2024 at 5:07 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    Total shot in the dark here - I experienced completely random stalling last year that neither an independent shop (their scanner told them it was transmission issue) nor the Toyota dealership (they thought it had to do with my aftermarket key) were able to diagnose. Truck would run fine for a day or week and then would stall multiple times while driving a short errand. I think I developed a little anxiety disorder over it! I was at a complete loss but using the OEM key seemed to be working... most of the time, so I kept driving. Came out one morning to find the battery had died. Hooked up the charger but no luck. I went to pull it so I could put in the replacement and, as I was loosening the negative terminal, it literally fell off the battery post. It had a hairline crack that allowed it to jiggle just enough to intermittently lose connection. Replaced the clamp and all has been good since!
    Long-winded way of saying you might want to check your terminal clamps!
    Jimmyh, Steves104x4 and asuchemist like this.
  3. Jan 22, 2024 at 5:54 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you cleaned the throttle body?
  4. Jan 22, 2024 at 7:23 AM
    MR5X5
    MR5X5 Well-Known Member
    If not an OEM MAF replacement it is still suspect.
  5. Jan 22, 2024 at 7:30 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Ignoring all of the variables and focusing on what seems to be the ones that are related to the issue:
    Going from pressurized air intake to vacuum (letting off the throttle) around 4K rpm.
    check for vacuum leaks first?
    this is assuming you haven’t touched anything else recently to try to fix this (new MAF, etc)
    But the question does stand - did you buy an OEM MAF from a dealer? Did you possibly end up with a counterfeit on Amazon or other?
    Doc Samson likes this.
  6. Jan 22, 2024 at 8:00 AM
    Mcmudflap
    Scott
    220+ 2nd gen 4.0
    Replaced the mef,have not cleaned the throttle body,I added some seafoam and separated my exaust after the manifolds and it ran good for about a week,so I thought it was plugged cats,deleted cats with obx stainless headers and y pipe,sounds a lot better still haveing the stalling issues,going to clean throttle body and get back to you,thank you all for the input
  7. Jan 22, 2024 at 8:02 AM
    Mcmudflap
    Scott
    220+ 2nd gen 4.0
    Got the maf from advanced auto
  8. Jan 22, 2024 at 3:22 PM
    Waasheem
    Waasheem
    2007 xrunner
    Do you know how many miles ago the spark plugs were changed? Id also check the fuel pump resistor.
    Aftermarket parts aren’t good, you should stick with oem.
  9. Jan 22, 2024 at 3:51 PM
    GearHead899
    GearHead899 Well-Known Member
    Justin
    Ocean View, NJ
    11' Black X-Runner, 06' RR X-Runner
    If its still doing it after the throttle body, disconnect the exhaust after the y-pipe and see if that does it. Its weird that disconnecting the exhaust before fixed it so maybe its a restriction in your muffler. Also, does the truck idle smoothly?
  10. Jan 22, 2024 at 4:12 PM
    Mcmudflap
    Scott
    220+ 2nd gen 4.0
    Going to clean throttle body tomorrow and check plugs,not coding anything, changed plugs a couple of years ago so probably due
