Standard Rear Bilstein 5100s with 1.5" AAL?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTacoma777, Jul 18, 2025.
  1. Jul 18, 2025 at 11:33 AM
    BlueTacoma777
    BlueTacoma777 [OP] Well-Known Member
    Hudson
    2005 Silver Tacoma TRD OFFR
    33 AT Tires 3” Bilstein F lift Rear leaf pack Shell Method wheels
    Hello,
    I was wondering if anyone had any information or experience with installing the standard length 5100s with a 1.5" AAL? The last owner put the AAL on the stock TRD shocks #48530-AD050. I also have a camper shell in the rear and certainly surprised that these shocks have helped up, even off roading. My current ride height from center hub to bottom fender is 23.25". My shock ride height is 21.5". Would the 5100s be fine to run, since even the stock shocks work fine? Im not gonna be doing any heavy off roading. I am a college freshman and would hopefully be able to not have put in extended brake lines or grind a bushing and bolt. Any advice or experiences would be greatly appreciated. Thanks!
  2. Jul 18, 2025 at 1:23 PM
    Pigpen
    Dan
    Northwest Montana
    The 5100 is technically an extended travel shock. It has more travel than the OEM shocks. You will be fine running them with a 1.5" lift add a leaf. They work for bigger lifts than that. Others could provide more technical information than I can about how much travel you are actually adding (pretty sure it's zero with an AAL) with various lift options.
  3. Jul 18, 2025 at 1:26 PM
    BlueTacoma777
    Hudson
    Are you thinking about the extended length 5100? There are two different sized 5100. Thank you for the info
  4. Jul 18, 2025 at 1:27 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    I had exactly that on my truck for about 4 years and it was fine. Technically the shock does limit downtravel, but that's kinda what you want. That's also how it works from factory. If you put a longer shock on you will need new brake lines and possibly new bumpstops.
  5. Jul 18, 2025 at 1:28 PM
    BlueTacoma777
    Hudson
    Yeah limited down travel would be better since I’m street driving most of the time. Did you also have an AAL with the standard 5100s?
  6. Jul 18, 2025 at 1:29 PM
    Saskabush
    Adam
    2013 TRD Sport
    I did yep. Toytec AAL.
  7. Jul 18, 2025 at 1:32 PM
    BlueTacoma777
    Hudson
    Great thank you! Will be buying the 5100s, since they have worked with a similar set up.
    also, any idea how the AAL has worked with my stock trd suspension, with no issues? Seems weird since the shocks I have on now weren’t made for lifts
  8. Jul 18, 2025 at 1:36 PM
    Saskabush
    Adam
    2013 TRD Sport
    The shocks don't necessarily need to be made for a lift. A lift just changes where in the travel range that the truck sits. The shocks still work exactly the same as before. The only concern is if you lift too much and run out of down travel (since lift always comes at the cost of down travel), which is where longer shocks help. But on the rear there is usually plently of down travel, it's up travel that is lacking. And longer shocks come with their own problems as well, such as being too tall when compressed, hence the need for new bumpstops.
  9. Jul 18, 2025 at 1:38 PM
    BlueTacoma777
    Hudson
    Ok cool thank you for the info and help.
  10. Jul 18, 2025 at 9:37 PM
    Pigpen
    Dan
    Northwest Montana
    No.
    5100s all have more travel than stock shocks. There are actually 3 lengths of 5100. The B110 is a 5100 for 4-6" lifts. I ran a set on the Taco for awhile.
    I really like the street ride of 5100s. Offroad they're pretty good too. They just don't last. I burn through them about every other year. I've had 3 sets.
    YMMV
    Somewhere i have a really good pic of the goo bubbling out of one of my 5100s. Couldn't find it though, so maybe it didn't really happen. :crapstorm:
  11. Jul 21, 2025 at 11:13 AM
    BlueTacoma777
    Hudson
    Sorry I seem to be worrying to much before I pull the trigger on the 5100s. Just for reassurance, if the stock TRD shocks work with the AAL, the 5100s for sure will work right?
  12. Jul 21, 2025 at 11:36 AM
    Saskabush
    Adam
    2013 TRD Sport
    Yep, should have 0 issues.
  13. Jul 21, 2025 at 11:46 AM
    BlueTacoma777
    Hudson
    Cool. Need larger bump stops?
  14. Jul 21, 2025 at 12:30 PM
    Saskabush
    Adam
    2013 TRD Sport
    You shouldn't, no. The AAL will add thickness to the leaf pack which will make the bump stops come into contact even sooner than before. So no concerns with the shock being too tall when compressed.
    That being said, new bump stops do help the ride quality quite a bit (on harder hits where you actually engage them). The stock ones are hard af.
  15. Jul 26, 2025 at 7:40 PM
    BlueTacoma777
    Hudson
    Just installed them, and it went pretty smoothly. Drove around for a bit and feel very stable. When I get out of the truck, I hear very minimal creaking noises from the shocks. Is that normal for them just being put on?
  16. Jul 26, 2025 at 11:59 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    I think I have this setup I didn’t think I had as much lift as I did and have 0-1 inches lift billstens but a 2 inch add a leaf that I didn’t notice until I measured my ride height.
    I haven’t noticed any issues it’s been almost two years.
  17. Jul 27, 2025 at 6:08 AM
    Saskabush
    Adam
    2013 TRD Sport
    Yeah probably just the wiper seals making a slip-grip noise as the shaft moves slowly up and down. Likely just dry from storage. Nothing to worry about, my bike shocks do that too. Should get better with time once the shafts cycle in and out of the shocks a few times. You can just give the shafts a quick shot of silicone lube too and that should make the noise stop.
  18. Jul 27, 2025 at 2:33 PM
    BlueTacoma777
    Hudson
    Great! Thanks
    Did you hear any slight minimal creaking when you first put them on? I just put mine on yesterday and when I get out of the truck I hear like the smallest amount of creak
  19. Jul 28, 2025 at 5:15 AM
    hdn4space
    hdn4space Well-Known Member
    FL
    2013 Silver SR5 4x4
    Been running that setup for about 11years now. No issues whatsoever!
  20. Jul 28, 2025 at 6:26 AM
    jbolts
    jbolts Active Member
    john
    2008 Tacoma TRD
    I think the 5125 is the version for 2"-3.5" of travel
