standard vs automatic
Discussion in '1st Gen. Tacomas (1995-2004)' started by alumaman, Aug 23, 2014.
  1. Aug 23, 2014 at 10:22 PM
    alumaman
    alumaman [OP] Well-Known Member
    Yukon
    95 Tacoma
    Header, cold air intake 2" body lift
    I'm looking for a 2.7 Tacoma 4x4 and would prefer a standard but there seems to be a lot more automatics out there. What are the pro and cons of the automatic 4 cyl?
  2. Aug 23, 2014 at 10:24 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    More mpg, less power.
  3. Aug 23, 2014 at 10:24 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Pros: you do not need to shift, easier to use for off roading depending on your style and preference of off roading.
  4. Aug 23, 2014 at 11:25 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    only pro to an auto is not having to shift or run a clutch. Manuals are typically stronger, more efficient, more control if you know how to use one, and less maintenance. As mentioned autos also rob more power.
  5. Aug 24, 2014 at 2:05 AM
    wkndboost
    wkndboost Active Member
    I wish I gotten a manual, it's a bit boring with an automatic.
  6. Aug 24, 2014 at 3:18 AM
    DrFunker
    DrFunker Well-Known Member
    Manual = control, brake life, MPG.
    Have an auto now. Was my one big sacrifice for the new truck.
    I miss the manual. :(
    But still have a great truck.
  7. Aug 24, 2014 at 5:04 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Just do a search of the number of manual transmission problems vs automatic transmission problems on this forum. Many manual transmission clutch problems. Seems automatic transmissions are much more reliable.
  8. Aug 24, 2014 at 6:00 AM
    Tjsingle26
    Tjsingle26 Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    I have an 03 xtra cab 4x4 2.7 manual, I really enjoy having a manual in the truck. Its fun to drive! I haven't personally driven an auto 2.7, but I am sure as others have said that it lacks power. For my needs of a truck, the 2.7 is great
  9. Aug 24, 2014 at 7:28 AM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    My 04 taco is a manual and my 00 4runner is a auto, both 3.4L 4x4's. Both have the 3" toytec suspension lifts and same size duratrac tires. I can't believe not only the difference in power but the mpg's my manual has compared to my auto. I know that the 4runner is a slightly heavier vehicle compared to my ext cab taco. Since i finally got my project taco on the road i'm throwing around the idea of converting my 4runner to a 5 speed manual.
  10. Aug 24, 2014 at 8:03 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Wait and find a manual. The auto is hard on gas and very slow, trust me.
    But really, if you plan on making any modifications you should look for a V6. They are strong and more efficient if you plan on adding any weight (towing, hauling, off-road bumpers, etc)
    If I could start again I wouldn't buy anything except a V6 TRD manual
  11. Aug 24, 2014 at 8:04 AM
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    Control the RPM more easily with manual and better shift points.
  12. Aug 24, 2014 at 3:10 PM
    alumaman
    Yukon
    95 Tacoma
    Manual it is, I use my duramax for towing and the taco for running around. 140.00 per week in the GMC 75.00 every two weeks with the Tacoma. I was looking at upgrading and there seems to be a lot more automatics for sale than manuals. Thanks for the responses.
  13. Aug 24, 2014 at 5:23 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    The reason I have a Tacoma is because it and the Frontier are the only manual trucks left. I've only ever owned manuals.
    The auto is listed as having better mileage than the manual when it comes to these trucks. The manual in the 2.7 Tacomas is the sloppiest, clunkiest I've ever driven and I've driven a lot.
    I'd still pick the manual over the automatic every time especially in a 4cyl.
