Standard vs Extended travel Kings, Fox, Icon
Discussion in '1st Gen. Tacomas (1995-2004)' started by Burro, Aug 17, 2018.
  1. Aug 18, 2018 at 12:15 AM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Pics of Tacoma’s are great for any measure :) welcome to the World
    Burro[QUOTED][OP] likes this.
  2. Aug 18, 2018 at 8:45 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
  3. Nov 27, 2018 at 5:47 PM
    Murdoch33
    Murdoch33 Well-Known Member
    2018 Black TRD Pro
    Sorry total noob on suspension...
    And I know I’m 3rd Gen but....
    BJs, TREs, rack bushings, LCA bushings?
    What do they mean and should I add/swap? I’m getting parts together to order from Headstrong.
    Thank you !
  4. Nov 28, 2018 at 9:26 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Keep reading, you are in the right place. BJ's are ball joints, (at least they are here, but equally important however). You have uppers and lowers UBJ, LBJ. Rack is a steering rack and the associated bushings. CA is a control arm on the front suspension, they have bushings on both. You have lowers and uppers hence the Lca and Uca. Uppers are whats frequently swapped. Lowers are generally swapped in a long travel or mid travel suspension setup. (LT or MT).
  5. Nov 28, 2018 at 6:05 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Ball joints, tie rod ends, steering rack bushings, and lower control arm bushings. Most of those things need replacing anyway due to age and mileage - normal wear and tear stuff...
    For a 3rd gen, you probably don't need to worry too much about those things. If you go mid travel (extended travel coilovers), you might consider polyurethane control arm bushings (upper and lower) since they give you a little better articulation since they don't bind like the stock rubber ones.
    OneWheelPeel likes this.
  6. Nov 28, 2018 at 9:08 PM
    Murdoch33
    2018 Black TRD Pro
    Thank you! Learned something new today.
    jbrandt[QUOTED] likes this.
  7. Aug 23, 2020 at 1:23 PM
    rickyg2008
    rickyg2008 Well-Known Member
    So would spc uppers get the full affect as a uni ball upper ?
  8. Sep 15, 2023 at 5:24 PM
    Carloss1017
    Carloss1017 Well-Known Member
    Carlos
    SoCal
    95.5 Tacoma 4wd 2.7L
    Quick question not sure if you know or could help me out … sorry for the noob question …. Do you think I could run the ext long travel 2.5 shocks with total chaos 1” UCA beside the oem king 2.5 shocks
  9. Sep 15, 2023 at 5:54 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Long travel shocks and extended travel shocks are not the same. Extended travel shocks should work fine with it a 1" uni-ball UCA. However, long travel shocks require long travel upper and lower control arms.
  10. Sep 18, 2023 at 6:12 PM
    Carloss1017
    Carlos
    SoCal
    I see, know I understand didn’t know that. Learn something new thanks for the reply. I just got a Tacoma and I plan to to build it slowly but surly. Just don’t know where to start. I been doing research/watching videos of different builds.
    since I don’t have a lot of money to drop all at once and I’m be daily this a lot this winter to go snowboarding. I plan to buy the lower ball joint that total chaos just release and some new tires. 265/70/16R hopefully they don’t rub and eventually down the line buy the 1” UCA and shocks.
  11. Sep 18, 2023 at 7:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Don't waste your money on those TC uniball LBJs. They are expensive and not the most effective use of the limited amount of cash you have to work with. Traditional OEM LBJs will work just fine for your situation at a fraction of the cost and leave you with money better spent elsewhere.
  12. Sep 18, 2023 at 8:24 PM
    Carloss1017
    Carlos
    SoCal
    Tha
    Got it. I’ll just focus on spending my money on something else. What UCA will you recommend For like a mid travel. Back to TC ,I was looking at there 1” uca or any recommendations on where I should start or brands
  13. Sep 18, 2023 at 9:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Mostly you would do an aftermarket upper control arm like a uniball type or perhaps an SPC ball joint type because you have added lift and then have trouble getting a good alignment.
    But if you are going to run a 31" tire (265/70r16), you may not need to add very much lift to clear them.
    Carloss1017[QUOTED] likes this.
  14. Sep 18, 2023 at 10:16 PM
    02 quadcab
    02 quadcab Well-Known Member
    If you live is some place that salts the roads don’t go with a uniball it will be exposed. Go with something like JBA uppers they are from Utah and sealed up so rust won’t be an issue.
    Carloss1017 likes this.
  15. Sep 18, 2023 at 10:35 PM
    #35
    Carloss1017
    Carlos
    SoCal
    I live in the west coast …. Only time I’ll be expose to salt roads will be when I go up to ski resorts. I’ll check them. Thanks
  16. Sep 18, 2023 at 10:46 PM
    #36
    Carloss1017
    Carlos
    SoCal
    I’m keep looking at different Uca and eventually buy one by the end of the month. Cool , thanks for replying
