StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Apr 17, 2014 at 8:24 PM
    #221
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    This is true:)
    I'd be ok with a magnaflow cat and muffler though... All 3" and all street legal. I'm seriously thinking about buying some 3" flex pipe and doing all that myself hmmmmmm :rolleyes:
  2. Apr 18, 2014 at 10:48 AM
    #222
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Never knew of a build to ever be problem free. Yours is coming together quite well even despite a few hiccups. :thumbsup:
  3. Apr 18, 2014 at 12:10 PM
    #223
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    tis the mere beginning...:p haha
  4. Apr 18, 2014 at 3:54 PM
    #224
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Make me one too? :p
    Yeah, I was supposed to get the truck back this week but still waiting for the new bumper. Having the truck in the shop is a HUGE hick-up :mad:
    Please don't say that... :eek:
  5. Apr 18, 2014 at 6:13 PM
    #225
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    So Ive been wanting new springs and u-bolt flip for some time. Broke down and got some OME springs and u-bolt flip. I have the shock relocation tabs already, just need some metal plates and a bar for the mount.
    Also getting rid of the light bar and FABTECH tire carrier in exchange for the SOS Concept all in one (bar and tire carrier).
    Brent, I might be needing some welding done sooner rather than later :eek:
    So here is my to-do list:
    -Troubleshoot FIC ground :(
    ______-Mount FIC behind glove box
    -Turbo kit install
    ______-Need to figure out the water lines
    ______-Need to figure out the IC (got the mount figured, just need to make sure I have the proper plumbing
    ______-Still need to decide how to run the oil lines
    ______-Need to purchase exhaust parts
    -Trans cooler
    -Oil filter relocation
    -Catch can install
    -3 Piece Belly Skid plate install
    ______Drill frame for trans skid
    -Redo wiring/fuse plate
    -Rear shock relocation
    ______-Need metal plates/bar
    -Rear leafs/u-bolt flip
    -Install new light bar and tire carrier
    -Install new headlight and reverse light bulbs
    -Clean/Vacuum/shampoo interior. Had a slight water leak on driver side door. Replaced weather stripping but now a funky smell.
  6. Apr 18, 2014 at 9:22 PM
    #226
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Damn your list is longgggggggg
  7. Apr 18, 2014 at 9:38 PM
    #227
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha...
    Ill give ya maybe November...maybe.
  8. Apr 18, 2014 at 9:53 PM
    #228
    GioGuitarDude
    Gio
    Cold air intake
    I just ordered my rear shocks and springs so :cheers:!
    I get the feeling you aren't going to like that monster turbo and get a smaller one after driving with it a while so I can't help with the water part of it, but all of the oiling and plumbing is cheap on ebay. I would buy like 10 feet of straight aluminum tubing and buy the silicone elbows and reducers instead of having it tig welded (8~ pieces at $5-8 a piece instead of a $200+ weld job). I'm going to use the tubing I have now which is 2". Nylon/stainless steel double braided 15,000psi oil lines are less than $5 a foot depending on how hard you look on ebay. 1/4" feed with 1/8" restricting hole and 5/8 drain. Fittings at Home Depot (or go fancy and get red/blue AN fittings on ebay free shipping).
    More oil lines exposed just to make sure there are no bubbles in oil after change/not have to squeeze your hand through wheel well is scary :eek: so .... Errrrr idk.
    Partsgeek.com has cheap oil/trans coolers for our truck and of course a universal one from ebay will work $30~
  9. Apr 19, 2014 at 5:07 AM
    #229
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Would help if I had the truck to knock some of this stuff out :mad:
    Always gotta be Mr Negative.... :p
    Sweet! What shocks/springs? I got some OME springs and running my 5100's.
    As far as the oil feed, I got my oil feed and drain lines for the turbo, I just don't want to do it how the CXRacing kit does as that may not let me relocate my oil filter. Just looking for a new and better way to run the feed lines :thumbsup:
  10. Apr 19, 2014 at 11:18 AM
    #230
    trdtoy
    trdtoy Well-Known Member
    North Carolina
    02 sr5 4x4 auto v6 turbo (sold)
    Turbo with supporting mods and tranny to hold power.
    Need a t fitting that is male 1/8" bspt one end(block side), female 1/8" bspt other end (oil pessure sensor side), and 1/8" npt feed for turbo. Also be sure restricted to 2an or 1/8" at turbo.
    Drain 5/8"/10an or larger from turbo to side of oil pan.
    How does cxracing have this setup?
  11. Apr 19, 2014 at 11:32 AM
    #231
    trdtoy
    North Carolina
    Should not be an issue with 5w-30.
  12. Apr 19, 2014 at 12:22 PM
    #232
    trdtoy
    North Carolina
    Be sure you can fuel it and tune fuel and ignition timing. Run 2 step colder plugs, 160-170 degree thermostat, high octane pump gas, coolant to/from turbo from throttle body circuit bypassing the throttle body, transmission oil cooler with fan and thermostat switch. Engine oil cooler only needed if ran hard for long periods. It will not get out of control easily when running 20-30 degree cooler coolant from colder tstat as this helps cool oem oil cooler and turbo chra. Feed and drain for turbo as I mentioned earlier. Intercooler not needed but good idea for best results. Water/meth not needed but will help as well.
  13. Apr 19, 2014 at 6:56 PM
    #233
    Blackdawg
    Monte
    Wyoming/St. Louis
    I prefer to think of it as incentive to prove me wrong :D haha
  14. Apr 20, 2014 at 10:10 AM
    #234
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Il have to look how the kit does it . Family in town for easter soo no time now.
    Mobile 1 makes a synthetic 0w 40. Has me interested. Otherwise amsoil 0w 30.
    Im looking into plugs now. I can adjust everything but timming. I can only retard timming with the fic. Thermostat is a good idea...
    I'm trying but I think you are being too optomistic :eek:
  15. Apr 20, 2014 at 1:55 PM
    #235
    GioGuitarDude
    Gio
    Cold air intake
    Just OME springs and plane jane Monroe shocks... blah.
    And I keep forgetting you got the whole kit :goingcrazy: so disregard that. But how exactly does the CX kit feed the turbo? Just the 3/8" npt tap by the filter? Where are you getting the relocate kit from? I might be able to tell if it will work with the oil tap since I've spent quit a bit of time down there /:
  16. Apr 20, 2014 at 4:51 PM
    #236
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The CX kit uses a plate that inserts between the block and filter similar to the plate the relocation kit uses.
    I go this JEGS kit: http://www.amazon.com/gp/product/B007WWVWQ0/ref=oh_details_o09_s00_i00?ie=UTF8&psc=1
    Im not comfortable stacking the two plates so I figured I can tap the relocation return line.
  17. Apr 20, 2014 at 4:57 PM
    #237
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    Sweet build up
  18. Apr 20, 2014 at 5:09 PM
    #238
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Would look better with a certain bar/tire carrier :D
    If you have some SOS Concept stickers I wouldn't mind a one in the rear window :spy:
  19. Apr 20, 2014 at 5:14 PM
    #239
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
    I sent you a Invoice lol and Ill have more stickers this week
  20. Apr 20, 2014 at 5:16 PM
    #240
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    Sweet. Send my sliders to my house and the invoice to chris's house.
