StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Sep 3, 2014 at 4:32 PM
    #461
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    I'll be there. I should at least have mine up and partially disassembled by the time you arrive. If you have any wiring concerns make sure to give me a heads up so I can bring stuff home.
  2. Sep 3, 2014 at 6:21 PM
    #462
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I don't think any wiring is needed; I got the corner blinkers wired up (put in a switchback in the corner lights). Thanks though.
    Though now that I think of it, I might need help id'ing how to hook up the leads on the guages. At least borrow your manual again.
  3. Sep 4, 2014 at 4:49 AM
    #463
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    The manuals are always available if you need them.:)
  4. Sep 4, 2014 at 3:41 PM
    #464
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    The compression of air isn't the only thing that creates heat with a turbo. I'm rockin the rear mount and my charge pipes still get pretty hot when driving in 100% vacuum (4 wheelin and slow traffic). I'm sure the radiant heat from the exhaust housing transfers to the cold side quite a bit. I wouldn't let somebody pay me to run a front setup without an IC regardless of how I drive.
  5. Sep 4, 2014 at 3:47 PM
    #465
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Have you measured your IATs with the rear mount? I'd be curious to know what they are.
  6. Sep 4, 2014 at 4:22 PM
    #466
    GioGuitarDude
    Gio
    Cold air intake
    No way dude I just ordered the rest of my charge pipes, couplings and clamps. I'm ordering the headers tomorrow. Might have to sell my body to the night to pay for the oil pan weld job and my boss to help me install everything LOL.
    I'm going to (try to) take it easy until a check or two later to get the FIC.
    Have you ever heard of running more than one muffler? These 3" straight through mufflers are still too damn loud. And are you going to have a post cat OEM O2 bung welded in?
  7. Sep 4, 2014 at 4:40 PM
    #467
    GioGuitarDude
    Gio
    Cold air intake
    I haven't but according to clownmeat's rear mount info they are anywhere around 30 degrees above ambient temps at full warm up standing still with occasional slight depression of the pedal. Driving around like a normal person at least 50 above ambient.
    All with no IC and the temps are supposedly being recorded at TB
  8. Sep 4, 2014 at 5:23 PM
    #468
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haha, I feel the same way. Been eating PB&J's for lunch lately.
    Ive heard of installing a resonator tube to keep down drone but not two mufflers :notsure:
    Due to fed regs, you will need two cats installed unless you can get a questionable shop to install the exhaust and may not have enough room for two mufflers.
  9. Sep 4, 2014 at 5:50 PM
    #469
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You didn't hear what I was saying. And I is totally worth it IMO. Putting a fan on the IC isn't.
    My dad has two mufflers on his supercharged truck. Totally fine to do that
  10. Sep 4, 2014 at 6:25 PM
    #470
    Robb235
    Chattanooga, TN
    1999 Turbo 4Runner
    Yeah, I've read through Clownmeat's thread. That's actually what inspired me to go the turbo route, lol. I was just curious to see if you had similar IATs to him.
  11. Sep 4, 2014 at 6:26 PM
    #471
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I was considering just a resonator pipe and the aero muffler. I hope it doesnt sound like shit. Im not too worried about being loud when on the throttle as the waste gate is going to be open... Im gonna have to be careful with that.
  12. Sep 4, 2014 at 11:22 PM
    #472
    GioGuitarDude
    Gio
    Cold air intake
    Lol for real man. I'm welding the exhaust myself so I'm not limited to anything. Speaking of limited I was looking at the inside of this high flow cat and noticed that even being "high flow" it looks pretty darn restrictive. I was thinking about either adding another cat in parallel or just welding in a bypass curve that's like 1.5" in DI and just teeing it back in after the final O2 sensor. Most people who completely redo their exhaust delete the cat all together so I'm sure that won't be too big of an issue. I'm probably WAY overthinking everything but I don't wana have to change it later.
  13. Sep 4, 2014 at 11:28 PM
    #473
    Blackdawg
    Monte
    Wyoming/St. Louis
    Is it fully divorced? If it is...it's gonna be loud no matter what in boost :D be awesome.
    My dad had a muffler and a resonator silencer thing. It helped a lot but didn't kill it. Still sounds great
  14. Sep 4, 2014 at 11:46 PM
    #474
    GioGuitarDude
    Gio
    Cold air intake
    I'm not sure with our v6 but I read a thread of some dude with a v8 truck who had to install SIX mufflers (3 resonators and 3 mufflers all 3" straight through) to get it down to where he wanted. Sounds pretty damn goofy to me but still... I don't want every kid in a honda accord and their mom trying to race me every time the light turns green like how my set up is now. I can always add another muffler/resonator later.
  15. Sep 4, 2014 at 11:56 PM
    #475
    GioGuitarDude
    Gio
    Cold air intake
    I'm sure my temps are a few degrees lower since he is still using schedule 40 PVC pipe as charge pipes. That insulates heat better than aluminum.
    He was my hero too when first thinking about boostin :)
  16. Sep 5, 2014 at 12:39 AM
    #476
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Haha. Goddamnit. Another turbo thread I read from beginning to end that isn't completed.
    Looking good.
    Have you picked up your coil overs yet? If not a decent alternative might be Radflo. I've been running them a couple months now and could not be happier. (2nd Gen though, couldn't tell you if they have what you need)
  17. Sep 5, 2014 at 8:17 AM
    #477
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haven't made a decission. If readers haven't noticed, I don't make any decisions finalized until I actually buy it. I'm not sure I want to take the chance with FOA; read some good, read some bad... Might just wait for used coilovers for sale (FOX, KING, or ICON).
  18. Sep 5, 2014 at 9:31 AM
    #478
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    What's up chris! How's the build going?
  19. Sep 5, 2014 at 9:46 AM
    #479
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Paul!! Been a while since ive seen you. It was great to finnally go to a meet and be the biggest 1st gen arround :D.
    Been meaning to call. There's a guy at my work who was interested in an MMA club but I think he's going to be too busy. I told him Id ask what club you were into anyways, just in case.
    Quick question, you still into welding? Ive been getting some coaching and plan to get a hobby welder in the near future.
    Oh by the way, I still have your u-bolts; neither fit (one was too long and the other too short :eek:). Ill hold on them until you want the back.
  20. Sep 5, 2014 at 9:52 AM
    #480
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    What muffler is he running? Going to need a new muffler after I get done crunching the stock one up in the rocks.
