StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Feb 11, 2015 at 9:21 AM
    #721
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yeah; you get a nice turbo and that easily another grand... I would love to get a nice twin scroll but for a target HP of 300-350, chinese turbos is good enough :notsure:
  2. Feb 11, 2015 at 9:29 AM
    #722
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Upgrade down the road. This setup will at least get you going. Might even be able to find a good used turbo. Like what MadTaco did. Found himself a used ball bearing Turbonetics.
  3. Feb 11, 2015 at 9:40 AM
    #723
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea a ball bearing twin scroll will make it spool much faster then a journal bearing.
    I agree with tor. You'll ne fine for now. But I'd definetly think about getting something different later. I'd even get a slightly smaller one for even faster spool.
  4. Feb 11, 2015 at 10:23 AM
    #724
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I would need new headers to take advantage of the twin scroll but its nice to dream :p
    I did get a smaller one. Turns on the turbo they sent was an 80mm so I sent that back and will get the new one this thursday/friday. Picked the smallest GT35 they had; he said it should start making positive boost around 2k-2.5k rpms, right where I wanted it :cool:
  5. Feb 11, 2015 at 12:07 PM
    #725
    Blackdawg
    Monte
    Wyoming/St. Louis
    They sent you an 80 originally?!?! That's not big..that's approaching fucking huge haha
    Sweet! Still tempted to do this myself one day..but..maybe not. We will see.
  6. Feb 11, 2015 at 12:14 PM
    #726
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Doo eet! Twin charge that shit; can do sweet jumps if you can't go fast!
    PS, cage first :p
  7. Feb 11, 2015 at 12:20 PM
    #727
    Blackdawg
    Monte
    Wyoming/St. Louis
    I may or may both and looked at twin charging a lot..last week..:anonymous:
    Some pretty funny opinions out there on it haha
    I'd turbo before cage though cause I'd have to have it in there to figure out how to do the engine cage with a snail In there haha
    It's only money right?
    I'm really anxious to see how yours turns out though. It's hard to justify a twin charge setup with the right sized turbo with our rpm range. A small turbo that starts boost at 2k even if it's 4psi..is well..on par with a supercharger about I think.
  8. Feb 11, 2015 at 12:32 PM
    #728
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Twin charged would be killer. You planning on building your engine?
    That's what I keep telling myself... :eek:
    You and me both...
  9. Feb 11, 2015 at 1:05 PM
    #729
    Blackdawg
    Monte
    Wyoming/St. Louis
    If I went win charge..yea Id build the motor. Probably talk the LCE about head work and cams to rasie the rev limit to better use the whole system. And the bottom end for certain. Probably go for the stock so pulley and 10 psi from the turbo so be about...22?? Psi total..or so. Be pretty cool to do.
    But who knows. I'm still in college haha won't have money for that kinda stuff for a while.
    I still like the idea of just slapping a 2jz in it and going from there haha
  10. Feb 11, 2015 at 1:15 PM
    #730
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    All of this twin charge talk seems so weird to me. My set up gives me positive pressure at 2000 RPMs and lag is non-existent. I know for a fact this little turbo could dish out 20 psi all day. Like black dog said get some head work done and replace the rods/pistons and cams for forged and the sky is the limit (or 600-700hp)
  11. Feb 11, 2015 at 1:25 PM
    #731
    Blackdawg
    Monte
    Wyoming/St. Louis
    A small turbo would get choked off before you hit 600. Won't move enough air.
    But with a small turbo on this motor, it makes perfect sense. Can't go over 5.5k anyways and you can make low boost easy. But more power then a supercharger.
  12. Feb 11, 2015 at 3:32 PM
    #732
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    A guy I saw did that to a mazdaspeed 3. Used a trd scion tc Sc and a big Garrett turbo. No lag boost at idle to red line. The sc spooled up the turbo
  13. Feb 11, 2015 at 4:36 PM
    #733
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    My only issue with the 2JZ is its a dog until its in boost. I drove a 700hp supra and it felt like a camry around town. Wasn't until 4500rpms that you started feeling the engine's balls drop.
    With a heavy ass truck as your's with big ass tires, might not be the best engine. I think it can be stroked to 3.2L but the 5VZ will still kick its but on the low end. Maybe if you did a sequential twin turbo setup...
    W/e, go graduate college and them we'll talk motor swaps :p
  14. Feb 11, 2015 at 5:19 PM
    #734
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I was gonna run the stock turbos in sequential. Upgrade them too. You can actually stroke the 2jz to 3.4l. But itll cost an additional 7k. Haha yet another problem with it is parts are pricey as fuuuuccckkkk.
    The built 5vz twin charged could be cool. Guess when I'm ready I'll price it all out. Idk how much it'll cost to build the 5vz. You are right the low end torque if the 5vz is nice and kinda needed haha plus the uniqueness is appealing to me for some reason..it's just...Frankenstien like too haha
    The supra you drove though no doubt had a single big snail on it so major boost lag. Smaller twins will solve that.
    Either way...you are correct! Need to get a real job before any of that nonsense happens haha
  15. Feb 12, 2015 at 9:00 AM
    #735
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Your wife is gonna cut your shit off while you sleep if you work on the truck Saturday
  16. Feb 12, 2015 at 9:48 AM
    #736
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, she and I discussed this. She's gone most of Saturday so Sunday we made reservations the Melting Pot. Just in case, I'm going to buy her a big ass vase of flowers.
    If you don't hear from me in like a week then I probably figured wrong. If you see my face on the news, I figured way wrong...
  17. Feb 12, 2015 at 10:14 AM
    #737
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
  18. Feb 12, 2015 at 10:14 AM
    #738
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea but at least you'll have turbo..lol
  19. Feb 12, 2015 at 10:18 AM
    #739
    DHwreckage
    DHwreckage Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    get a holset :D thats what i want on my LC!
  20. Feb 12, 2015 at 3:00 PM
    #740
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Haha, we hope.
    I'm probably going to be living out of my truck next week... :pout:
    BUT TURBO!!! :burnrubber:
    I got her flowers, chocolate, wine, and pizza today. Gonna blitzkrieg her this weekend so she ignores all the packages coming in :spy:
