StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Mar 13, 2015 at 10:52 AM
    #941
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The Early model Borg Warner EFR turbos were prone to failure as well. They had turbine housing casting issues, but those weren't a failure problem. The failure problem was that so many people are used to Inconel turbine wheels. Those turbos can a handle over boost, which means over speeding the max rpm, by a fairly large rpm. The Inconel is very strong.
    The EFR turbine wheel is titanium aluminide. Strong and I think, 30% lighter than Inconel. However, it cannot handle over speed, like Inconel. So people weren't limiting the the speed of acceleration of the turbo,and over boosting small turbos, versus stepping up to the next size. Turbine wheels were flying apart! Took a while for people to understand that, despite BW giving out explicit instructions with each turbo. Even has a port on the compressor housing for a speed sensor. But what does BW know. ;)
  2. Mar 13, 2015 at 11:10 AM
    #942
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yeah, I'm of the opinion that most failures are user error. You need to understand the quality and capabilities of the equipment you are working with...
    In other news, the trans issue is back. I think there is a loose signal connector or the stupid shop didn't disconnect the batter before welding and fried the ECU. Going to start testing the ECU this weekend.
    Looking to buy a new DD and get rid of this 1980 POS Tercel. I priced out the new wheel bearing and clutch and it comes out more than the car is worth.
  3. Mar 13, 2015 at 11:18 AM
    #943
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  4. Mar 13, 2015 at 11:23 AM
    #944
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah. Always something. I don't think the truck will last the month. My wife is about to burn this shit down and Im about to let her :p
  5. Mar 13, 2015 at 11:39 AM
    #945
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    I have a sweet 95 Chevy pickup you can buy :)
  6. Mar 13, 2015 at 11:41 AM
    #946
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    For FREEFITTY?
  7. Mar 13, 2015 at 4:33 PM
    #947
    cdj1
    Clint
    Muuurville, TN
    97 Tacoma
    Close
  8. Mar 13, 2015 at 5:57 PM
    #948
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    Dude...... what trans issues?
  9. Mar 13, 2015 at 6:46 PM
    #949
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not sure but was getting no/weird shifts and a shift solenoid code. Seems to drive fine now and no shift code with the FIC pulled out, however it didn't go into reverse once until I shut off the truck and restarted.
    It's either the welding shop didn't disconnect the battery and damaged the ECU (or FIC) or the FIC had a bad flash (or went bad). Im leaning towards the FIC unit as it drives MUCH better with it out. Let me fix the O2 tomorrow before diagnosing any further.
  10. Mar 13, 2015 at 7:44 PM
    #950
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    You'll figure it out! Don't "cut your losses" and back out now. Pioneering takes time.
  11. Mar 14, 2015 at 11:14 AM
    #951
    GioGuitarDude
    Gio
    Cold air intake
    Are you talking about the AEM FIC or the truck's ECU? It just seems like disconnecting the battery would be the simplest level of common sense at a *welding shop*. Heck even I knew that. Have you tried reseting your ECU (disconnect the positive terminal and touch it to the negative post)?
  12. Mar 14, 2015 at 4:39 PM
    #952
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Honestly not sure whats going on. Had it just happen again. I turned off the truck and restarted and trans ran great :notsure:
    Right now no codes but if it could throw a "ghetto" code, it would for the turn signals I just wired up... :facepalm:
  13. Mar 15, 2015 at 1:11 AM
    #953
    GioGuitarDude
    Gio
    Cold air intake
    Lol sorry to hear that bro :D
  14. Mar 15, 2015 at 5:23 AM
    #954
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Wtf! Boost needs no turn signals
  15. Mar 15, 2015 at 5:26 AM
    #955
    rbraddock
    rbraddock Well-Known Member
    Randy
    Hampton, VA
    13 DCSB
    6" ProComp lift from the dealer, slow build in progress
    I just blew bacon and eggs everywhere. Turn signal - turbo kill switch. So you're not coming to Phil's?
    Paul, as our token Asian in the group, you should look at this Chinese turbo build and do some lo mein, teriyaki, ninja, Kung fu to beat it into submission.
  16. Mar 15, 2015 at 5:30 AM
    #956
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Have you tried wiring the turn signals to the shift solenoid? Maybe you could signal the transmission to shift
  17. Mar 15, 2015 at 5:31 AM
    #957
    rbraddock
    Randy
    Hampton, VA
    13 DCSB
    :eek:h snap:
  18. Mar 15, 2015 at 5:37 AM
    #958
    ajohnson
    Andy
    Charlotte, NC
    Right turn = up shift, left turn = down shift
  19. Mar 15, 2015 at 5:40 AM
    #959
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Hell yeah....paddle shifters in turbo first gen taco FTW!!!
  20. Mar 15, 2015 at 5:41 AM
    #960
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    Cut your losses... $500 right now and I'll take that truck off your hands.
