StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Mar 19, 2015 at 6:35 AM
    #1021
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    Damn this thread.. Looking for boost videos and I'm getting chasing problems talk. Chris I hope you get this all figured out. Was excited to see this in person.
  2. Mar 19, 2015 at 6:40 AM
    #1022
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ha, Ill let you drive it when its done if I can drive your truck. Want to see how it feels with 35's + gears. Might go to 35's in the future, but that's just my ADD talking, need to focus one thing at a time and get this shit figured out :p
  3. Mar 19, 2015 at 6:45 AM
    #1023
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
    My shit! You don't want to drive my POS.. It's slow as fuck. Wait a minute yours is slower since it's broken.
  4. Mar 19, 2015 at 6:54 AM
    #1024
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Want to test out my LT kit too. We all know Im gonna buy that shit when you go three link SAS :p
  5. Mar 19, 2015 at 6:54 AM
    #1025
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Both are faster than mine!:D:D
    I don't have one atm.......;)
  6. Mar 19, 2015 at 6:59 AM
    #1026
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    When you get that 4runner, you'll be in business!
  7. Mar 19, 2015 at 7:50 AM
    #1027
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Well, trying to help chase something through verbage is near impossible, which I've learned more than a time or two through trying to troubleshoot Navy issues through distance support, so I'm done here... I'm sure I'll see updates in the 757 one year when this thing runs.
    You apply for Walmart sponsorship yet ? might help with funds... anyway, good luck, keep up the good/hard work !!! :cool:
  8. Mar 19, 2015 at 9:07 AM
    #1028
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Dude your going to ruin that turbo if you don't get a BOV.
  9. Mar 19, 2015 at 10:02 AM
    #1029
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    I don't know of any engine that has both the intake and exhaust valves open at the same time... that certainly isn't the case with a 3.4 5vz-fe (I've done this over and over again to check for leaks, and i know it works) And if it does stop on an intake cycle, then the hole which the air is escaping will be the tiny compression ring gaps in the piston and not the intake piping as I've said twice now (read much?). We aren't talking about subarus and nissans, we are talking about a Tacoma with a 3.4 5vz-fe... and I have plenty of experience with turbocharging these trucks. We are trying to help him diagnose his crappy idle quality, not coach him on where to put the BOV and MAF for full boost conditions (I'm not anyway)
  10. Mar 19, 2015 at 10:17 AM
    #1030
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    2 stroke Tacoma ftw :D
  11. Mar 19, 2015 at 10:20 AM
    #1031
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How was the FIC adapted to the OEM harness? Through the use of an extension harness (plug n play harness) or wired directly into the OEM harness?
    Either way, I would start by checking over those connections very carefully. That is where I believe the issue is.
  12. Mar 19, 2015 at 10:25 AM
    #1032
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    never heard of overlap huh ?
    but anyway I don't give a flying fuck what the turbo is on... an engine is an engine
    *** drops the mic
    edit: needed to leave this here http://www.hotrod.com/how-to/engine/116-0403-camshaft-basic/
    take a read under the lobe seperation section
    man, how does anyone do a compression or leak down test with that tiny hole in the compression ring... pffffff, hahaha
    you're trying to make someone feel silly who can build an engine in their sleep and design a turbo system while on the shitter
    get fucking educated before you talk to me... I'm done here
  13. Mar 19, 2015 at 11:25 AM
    #1033
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Whoa............m That guys dog die?
  14. Mar 19, 2015 at 11:43 AM
    #1034
    GioGuitarDude
    Gio
    Cold air intake
    Lol who said I was trying to make you feel silly? A half brain monkey can tell if the intake is hissing when you blow in it as opposed to lower in the block/heads. You're telling him to throw his MAF in front of the turbo to solve idle issues, and I'm telling you that doesn't matter *because I've been there done that*. I'm telling you that you can get a good idea if your intake has a huge ass leak in it by blowing in it *because I've been there done that*. No need to go on an ego trip Mikey.
  15. Mar 19, 2015 at 11:45 AM
    #1035
    GioGuitarDude
    Gio
    Cold air intake
    Yeah I meant any toyota engine lol
  16. Mar 19, 2015 at 12:33 PM
    #1036
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ive had a very thorough discussing over this on CustomTacos.com. Here's a discussion on it; I know a few ppl that have over 50-100k miles on their DD turbo trucks and no BOV.
    http://www.mr2oc.com/showthread.php?t=445311&page=3
    Here is a diagram that measures the pressure no BOV (the peaks are the fluttering). I agree, on-compression surge is bad, but off compression surge is very manageable. Unless Im running the turbo at absolute max, I should be good with no BOV.
    Im not going to swear on this as Im far from an expert but since I plan on a new turbo later down the road, Im ok with the risk. This way, the truck doesn't sputter or stall when the BOV releases manifold pressue. I wouldn't try to convince anyone either way, just what I chose :notsure:
    Wire harness. I ran though it briefly, nothing major or easy to pick out. Ill check it out more thoroughly this weekend, good call :thumbsup:
    Don't even try. I just put him on Ignore; a wonderful feature everyone should be familiar with :thumbsup:
    If you want to continue your discussion though, please do it via PM. I don't want this thread to be derped up.
  17. Mar 19, 2015 at 12:58 PM
    #1037
    ponethousand
    Paul
    Virginia Beach
    04 trd dc limited
  18. Mar 19, 2015 at 2:34 PM
    #1038
    GioGuitarDude
    Gio
    Cold air intake
    Sorry bro I just hate keyboard commandos who talk a lot of unnecessary smack. Tryin to back you up man.
    Anyway did you get your new Honda runnin good? And about the BOV... I ran one for about a year and my truck drove just fine. I'm not worried about driving without one, but I won't pass up a smokin deal on a good one either though.
  19. Mar 19, 2015 at 3:26 PM
    #1039
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No worries, and I appreciate it, just trying to keep it civil in here. Its ok to have a disagreement but there are ways to discuss things with tact. I've been there, done that, its not worth the effort.
    Anyways, parts are on order. Everything should be in by Friday/Sat except the spark plugs. I'm not sure the new O2 sensors will get rid of the check engine light, I think at 178k miles I might need new cats as well :eek:
  20. Mar 19, 2015 at 3:42 PM
    #1040
    GioGuitarDude
    Gio
    Cold air intake
    Lol I ran my truck pig rich because of bad O2 censors that I was too young to know how to replace or why from like 180k to 230k and my cat was perfectly fine when I chopped it off to install on my 4Runner. That ECU reset trick that I've bored you with works great for stuff like that :D
    Just did it to my aunts hundai because she had 4 or 5 codes and her CEL is still off 2 months later.
