StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Mar 23, 2015 at 9:53 AM
    #1081
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Yes, major PITA. I love driving manual trans and was very upset the 4-doors only had autos. However, the first time taking it off-road I fell in love. Autos are so easy!
  2. Mar 23, 2015 at 10:20 AM
    #1082
    cdj1
    cdj1 Well-Known Member
    Clint
    Muuurville, TN
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    FTFY
  3. Mar 23, 2015 at 10:41 AM
    #1083
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Don't hate. Im just lazy :p
  4. Mar 23, 2015 at 11:42 AM
    #1084
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    How does seafoam help detect leaks???
  5. Mar 23, 2015 at 12:49 PM
    #1085
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Well if you have a leak like this, not very helpful in detecting where it is:
    https://www.youtube.com/watch?v=ixQQxde_xeQ
    But generally, you just rev the engine and look for smoke coming out of your exhaust. Remember, at idle, generally your exhaust is sucking air in.
    Update: Got the other side of the crossover done. Now, the female v-band ends aren't super bad, generally they want to sit flush. The issue with the crossover is its off just a bit and for one side to sit flush, the other side is slightly off. Additionally, when fitting it, it has to be perfectly rotated or one side will be tweaked. I got it as good as I can by taking it slowly and tightening it evenly on both sides. Unfortunately, it wasn't good enough... The stove top adhesive should fill the gaps and seal it good though.
  6. Mar 23, 2015 at 12:58 PM
    #1086
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    At idle the engine is sucking exhaust in? What kind of sense does that make!?
  7. Mar 23, 2015 at 1:07 PM
    #1087
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Generally at idle, your exhaust is a slight vacuum which is why my AFR's are going screwy at idle and good at load. Its sucking air in and offsetting the AFR readings :notsure:
  8. Mar 23, 2015 at 1:42 PM
    #1088
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Is this piece of scrap running yet ? What was the problem ? Are you going to Potts ? I want to joke this thing, I mean check this thing out in person !!! MOAR BOOST !!!
    But nah, seriously, I'll try not to be a dick anymore, is it running better yet ?!?!?
  9. Mar 23, 2015 at 1:51 PM
    #1089
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Not yet, exhaust leak at the crossover pipe. Ill test it again tonight/tomorrow to see if today's efforts yielded any improvements.
  10. Mar 23, 2015 at 3:25 PM
    #1090
    GioGuitarDude
    Gio
    Cold air intake
    That can be the case sometimes but not always. It's kinda like a toilet Gray. When you have enough of something traveling through a channel, the momentum of it keeps it going straight and that creates vacuum if the hole (or leak) doesn't interfere with the main path
  11. Mar 23, 2015 at 5:41 PM
    #1091
    gray223
    SE Missouri
    2014 Tundra Limited
    I get that but that doesn't explain why you have flow going backwards at idle
  12. Mar 23, 2015 at 6:59 PM
    #1092
    GioGuitarDude
    Gio
    Cold air intake
    No it doesn't go backwards... he meant the leak hole sucking in air and pulling it out of the tail pipe because of the vacuum
  13. Mar 23, 2015 at 7:46 PM
    #1093
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Backwards flow?? :confused:
    This ^ Go back to high school physics :p
    On the ships we use S-type eductors to dewater flooded spaces. Same principle.
    Oh, and truck running MUCH better. Going to see how it runs over the next day or so then on to checking the AEM FIC and reconnecting. Hopefully it will be on the dyno by next January....
  14. Mar 23, 2015 at 8:44 PM
    #1094
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Progress is progress. :thumbsup: The stupidest little things cause the greatest headaches....
  15. Mar 24, 2015 at 7:30 PM
    #1095
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    One more puzzle piece. Also noticed some smoke coming out of the cheap waste gate. Got a 38mm OBX that Ill hopefully install this weekend. I was always planning on a Tial down the road but heard OBX was very good and much cheaper.
  16. Mar 25, 2015 at 2:58 AM
    #1096
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Have I missed the videos of this beast in action??
  17. Mar 25, 2015 at 3:59 AM
    #1097
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Hey Chris I still have those factory service manuals for you.
  18. Mar 25, 2015 at 5:06 AM
    #1098
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No, there is an idle video a few pages back. Still working out some kinks...
    I actually found them online and downloaded them but Ill take the books too.
  19. Mar 25, 2015 at 10:45 AM
    #1099
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Tial makes a nice waste gate, I've installed several of the larger ones on a few 1JZ motors.
    OBX ?!?!? That is a name I haven't seen in a long while, surprised their cheap asses are still around, though for the budget builder they didn't have bad products so long as you knew you'd be replacing the item down the road.
  20. Mar 25, 2015 at 12:31 PM
    #1100
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
