StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. May 21, 2015 at 10:04 AM
    #1281
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Working on it...
  2. May 21, 2015 at 12:34 PM
    #1282
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
  3. May 21, 2015 at 5:06 PM
    #1283
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    one....ONE...trip?!
    dude...come on..haha
  4. May 21, 2015 at 5:23 PM
    #1284
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, I figured I set my goals high and see what I can get.
  5. Jun 4, 2015 at 6:48 AM
    #1285
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Its been a while and a lot of work. Finally I joined the elite of turbo tacoma. Woot!
    Boom......
    :infantry:
    Torspd, RedLantern and yota243 like this.
  6. Jun 4, 2015 at 7:12 AM
    #1286
    j0shu4
    Right about cx clamps. Bolt snapped when tightening.
    Any suggestions where I can find variable voltage to increase my methanol pump as throttle increases?
  7. Jun 5, 2015 at 6:51 AM
    #1287
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Fuck yeah, looks good! Yeah, didn't even mess with those shit clamps. No really sure, most people map their meth off of boost though.
  8. Jun 5, 2015 at 9:30 PM
    #1288
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you don't want Meth being injected without beingin boost. How almost all Meth kits work
  9. Jun 6, 2015 at 1:56 PM
    #1289
    GioGuitarDude
    GioGuitarDude Well-Known Member
    Gio
    96 TURBOCHARGED 5 speed X-cab 3.4 DLX tacoma
    Cold air intake
    That's what I thought/said :notsure:
  10. Jun 7, 2015 at 7:24 AM
    #1290
    j0shu4
    How/where can I map it off boost? I really need this methanol situation worked out. Had issues with the controller spraying non stop. That wasn't fun.....
  11. Jun 7, 2015 at 11:09 AM
    #1291
    Blackdawg
    Monte
    Wyoming/St. Louis
    sounds like a kit issue to me. Call them. Or look up more about the kit itself. Ive never heard of Meth injection doing that.
  12. Jun 8, 2015 at 10:18 AM
    #1292
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Damn that looks clean. :thumbsup:
  13. Jun 9, 2015 at 11:13 AM
    #1293
    j0shu4
    Was going to get bigger injectors and the fic6.....did you find a plug and play harness for that? Hoping also you could pass along any useful info regarding this piggyback. Maps, wiring, etc.
  14. Jun 9, 2015 at 11:18 AM
    #1294
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Boomslang makes a harness for $350 I believe. I bought an extension harness from AEM and just spliced my wires into that. Both harnesses are also built to order so long lead time. Wiring was pretty easy. I figured out the wires to splice and @Rons01TRD did the wiring.
    http://www.boomslang.us/aem-fic.php
  15. Jun 9, 2015 at 11:20 AM
    #1295
    j0shu4
    thx. As long as I can get a good baseline of what goes where, I will splice wires all day to save 350.....for a harness, really?
  16. Jun 9, 2015 at 11:32 AM
    #1296
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I can't find the AEM harness part number but I think it was around $170. You will have to call them to order I think. URD makes one too for $189.
    http://urdusa.com/store/Electronics-Plug-N-Play-Harnesses/c66_124/index.html
    If you still have your stock ECU, you should be Type C harness. You can have URD do the wiring too for an extra $40. I don't know if they will do AEM wiring though, they tend to only support products they sell so probably only the MAP ECU unit :notsure:
  17. Jun 9, 2015 at 4:58 PM
    #1297
    Blackdawg
    Monte
    Wyoming/St. Louis
    350 is cheap.
    1800 for a 2jz one
  18. Jun 9, 2015 at 5:43 PM
    #1298
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I did the urd jumper. Pretty much the cheapest option unless you can source the connectors yourself. Works great for 150. I just used a service manual to check my work. Made it pnp with everything. Added a feature like egr delete. Getting the itch to do maf elimination next. It's ugly but no one sees it.
  19. Jun 10, 2015 at 12:56 PM
    #1299
    j0shu4
    Putting my fic in now. Is there anything I need to know. Is there a resistor that needs to go somewhere?
  20. Jun 10, 2015 at 12:59 PM
    #1300
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes. Ill have to get my notes when I get home but I believe there is a resister for the cam shaft sensor. Do you have a patch harness?
