StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Feb 11, 2016 at 12:01 PM
    #1421
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No room for a little heat?
  2. Feb 11, 2016 at 12:04 PM
    #1422
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    On the pulley? Haven't tried yet. A little room.
    What really needs heat is my damn garage; its in the 30's and tomorrow the 20's and this weekend the teens. Not much work is going to get done one way or the other.
    Got to research this part number and the P/N for my new oil pump seals (fucking thing didn't come with any seals :facepalm: )
  3. Feb 11, 2016 at 12:42 PM
    #1423
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Put a heat gun on the pulley, it should expand before the crank then gently tap on it with a hammer. If that doesn't work spray some Kroil or PB Blaster penetrating oil on it and let it sit, then repeat. Good Luck! I'm busy with the kids this weekend or I would come by and give you a hand.:(
  4. Feb 11, 2016 at 12:55 PM
    #1424
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I soaked it with some liquid wrench. Not worried, no hurry. Probably not going to get much done this weekend; too cold. I think we're expecting 1-3" tomorrow.
    In other news, going to have to remove the oil pan to replace the oil pump. FML. I think its just the relief valve stuck open; if I can fix that, I might not replace the oil pump after all... But I'm not sure I want to risk it. Fuck.
  5. Feb 11, 2016 at 3:19 PM
    #1425
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'll take the turbo before you C4 it.
    Thanks man.
    haha
    StAndrew[OP] and nfs257 like this.
  6. Feb 13, 2016 at 9:57 AM
    #1426
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  7. Feb 13, 2016 at 1:17 PM
    #1427
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  8. Feb 13, 2016 at 2:18 PM
    #1428
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    gray223[QUOTED] likes this.
  9. Feb 13, 2016 at 6:53 PM
    #1429
    gray223
    SE Missouri
    2014 Tundra Limited
    I'm curious if you can really tell the difference with the light weight pulley
  10. Feb 13, 2016 at 7:02 PM
    #1430
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Couldn't say for sure. I know the stock pulley is heavy has shit (10lbs at least) due to the harmonic balancer. The issue with the lighter pulley is you lose the balancer and you'll get more vibration from the motor. Some say this can damage the engine; I couldn't say. TBH, its too expensive, Ill probably get a dorman replacement for $90.
  11. Feb 13, 2016 at 10:17 PM
    #1431
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Wondering same. If it really does much for $180. Would be nice tho
  12. Feb 13, 2016 at 10:34 PM
    #1432
    Blackdawg
    Monte
    Wyoming/St. Louis
    BORING!!!
    WHERES DA BOOST?!
    j0shu4 likes this.
  13. Feb 14, 2016 at 6:34 AM
    #1433
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Turbo is on the floor right now. Redoing the oil feed and drain. Going to get some custom hoses made probably.
    Blackdawg[QUOTED] likes this.
  14. Feb 14, 2016 at 10:28 AM
    #1434
    gray223
    SE Missouri
    2014 Tundra Limited
    What happened?
  15. Feb 14, 2016 at 6:16 PM
    #1435
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I didn't like the drain; it didn't allow me to adjust the angle of the turbo to be straight up and down (oil feed and drain) and oil was pooling in the turbo and leaking into the intake. Also didn't like the cheap feed line.
    Torspd and gray223[QUOTED] like this.
  16. Feb 15, 2016 at 6:57 PM
    #1436
    j0shu4
    I'm confused. Whats wrong? I think you're water cooled like me. Turbo should be clocked right? Mine is clocked like 30° or so.
  17. Feb 15, 2016 at 7:08 PM
    #1437
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Some say the oil drain should be straight up and down to allow all the oil to drain. If not, it will pool and leak into your intake.
    Some say the oil drain should be just a little clocked to allow a tiny bit of oil to pool for startup to insure the turbo is well oiled.
    My is clocked way too much and I get a lot of oil pooling and seepage into my intake. The oil drain fitting is too bulky to clock it up and down as it hits the exhaust flange.
    Got a local shop that does custom oil feed lines/drain lines and I may go to them.
  18. Feb 15, 2016 at 7:53 PM
    #1438
    j0shu4
    Yeah, mine hit the flange too. Thats the main reason why I had to clock it. For however it worked, the way it ended up being clocked to clear the t3t4 was perfect for me with the coolant setup. Sucks that it leaks. Are all the bolts on your turbo tight?
  19. Feb 15, 2016 at 8:09 PM
    #1439
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, they're tight. Yours doesn't leak? Weird.
  20. Feb 16, 2016 at 8:49 AM
    #1440
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    j0shu4 and gray223[QUOTED] like this.
