StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Mar 4, 2016 at 4:59 AM
    #1461
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Mar 5, 2016 at 7:21 PM
    #1462
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  3. Mar 5, 2016 at 9:07 PM
    #1463
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It depends. www.kozmicmotorsports.com makes them per request.
    Had that done with quick turn around, with length and specific ends. Just tell them what length and the type/size of ends you need.
    Or build your own with Aeroquip stainless braided line, and stainless steel fittings.
    The Kozmic lines come black coated over the stainless braid.
    StAndrew[OP] likes this.
  4. Mar 8, 2016 at 2:10 PM
    #1464
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Oil and water pump/thermostat installed.
  5. Mar 9, 2016 at 10:51 AM
    #1465
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Got my new radiator. Mounted the used flexalite fans, will probably have to clean up the wiring a bit.
    Koyo Rad def has a much higher "fin per inch" count and narrower channels which should give some marginal cooling increases.
    Koyo:
    OEM:
    Old/used/original controller which is not sealed, looks like it shorted (top right), has the cheap thermostat that is shoved into the fins of your rad, and doesn't have the controllability I wanted.
    New upgraded controller (TBH, Flexalite should have included this with the original fans in the first place):
    Tap and screw temp sensor (need help; where do I tap for this?):
  6. Mar 9, 2016 at 10:56 AM
    #1466
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Pretty sure that goes into an open spot on the rad where coolant will register as is doesn't look like a rad core fin probe
  7. Mar 9, 2016 at 11:00 AM
    #1467
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No fittings on the rad to install it. The rad ends are plastic like OEM so not to interested in tapping those at the moment :notsure:
  8. Mar 9, 2016 at 11:06 AM
    #1468
    j0shu4
    I'm pretty positive that's a tap. No destructions came with it? Find the number of the manufacturer and call. My best educated guess is you tap it into the rad and use some epoxy or silicon to make sure it's sealed. Just trying to help out.
  9. Mar 9, 2016 at 11:09 AM
    #1469
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Hahaha, yeah I bought it because it was a tap :D
    I'm sure the best place to tap it is in the bottom of the radiator but I don't feel good with doing it in the plastic. Is there another place to put it?
  10. Mar 9, 2016 at 11:11 AM
    #1470
    j0shu4
    Not that I could think of unless on the block by the other oe temp probe.
  11. Mar 9, 2016 at 11:12 AM
    #1471
    j0shu4
    Had to leave you this....
  12. Mar 9, 2016 at 11:16 AM
    #1472
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I wonder if I can tap into the stock sensor?
  13. Mar 9, 2016 at 12:02 PM
    #1473
    j0shu4
    I'd be more worried taping into the block than your rad
  14. Mar 9, 2016 at 12:04 PM
    #1474
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I meant taping into the wires and just use the stock sensor signal.
  15. Mar 9, 2016 at 12:07 PM
    #1475
    j0shu4
    Doubtful if the voltage will be accurate. But would be super cool. Another option is to get a fin probe that just pushes into your rads core fins. Prolly get one off ebay or Amazon for like $10
  16. Mar 9, 2016 at 2:41 PM
    #1476
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, that's what the flexalite kit comes with and I'd rather not :notsure:
    We'll see; I'll probably drill a hole in the rad and mount it there.
  17. Mar 9, 2016 at 3:58 PM
    #1477
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Torspd likes this.
  18. Mar 9, 2016 at 4:04 PM
    #1478
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Why not just pull coil plugs and crank her over?
  19. Mar 9, 2016 at 4:57 PM
    #1479
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, I was thinking of pulling the EFI solenoid but I want to be sure. First time I did anything this big and I want it to be the last time (for a while at least).
  20. Mar 11, 2016 at 9:50 PM
    #1480
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I had to pull my flexalite fans last summer. I did like how responsive the motor was with efan, but they couldn't pull enough heat for me. If I do it over again I'd upgrade the motors to brushless. I do miss the efan. The stock fan reminds me of a junky ford truck.
    I'm not exactly easy on motors. It was 107F outside and I was trying to haul ass in sand.
