StAndrew's Build
Discussion in '1st Gen. Builds (1995-2004)' started by StAndrew, Nov 23, 2013.
  1. Oct 31, 2016 at 5:22 PM
    #1601
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  2. Nov 2, 2016 at 5:01 PM
    #1602
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You might be right. You know a reputable place?
  3. Nov 2, 2016 at 6:05 PM
    #1603
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Best place I know of is in Chesapeake, All Aspects
  4. Nov 2, 2016 at 6:27 PM
    #1604
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Was just on their page. I'm between them and Ramy Built. Ramy B did my exhaust and the guy there is familiar with the AEM FIC.
  5. Nov 5, 2016 at 12:43 AM
    #1605
    White Stripe
    White Stripe Member
    So at what rpm does boost start to build and what rpm to you get max boost? Your using the turbo that came with the cx racing kit right?
  6. Nov 5, 2016 at 1:54 PM
    #1606
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I opted for a their smallest turbo that still fit the kit (without mods). I can't remember the specs. I don't boost yet, trying not to blow a rod. At about 2500 rpms and a heavy throttle (not full), the boost gauge reads "0". I accidently hit the gas a little too hard pulling into traffic from a stop and the boost came on pretty quick, spun some tires. Its not instant but lags isn't bad. What I like about it is I can drive the truck pretty much like it was stock until I need the extra power.
  7. Nov 5, 2016 at 4:01 PM
    #1607
    White Stripe
    White Stripe Member
    Throw a rod? What is your your wastegate set at? I have run 8psi or so with just the free fmu hooked up and the front O2 sensor unplugged. It keeps afr readings pretty decent under boost to an extent.
  8. Nov 5, 2016 at 6:28 PM
    #1608
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, I'll wait for a proper tune I think :notsure:
  9. Nov 5, 2016 at 6:30 PM
    #1609
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Hey what are u using for engine management? Im trying to get a mapecu3 group buy together just sayin.
  10. Nov 6, 2016 at 2:10 PM
    #1610
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    FIC. MAPECU is a better piggyback for this truck I think but the FIC was a lot cheaper. I don't think the MAPECU3 can tune injector pulse width but it is able to advance timing where as the FIC can only retard.
  11. Nov 6, 2016 at 2:14 PM
    #1611
    yota243
    E.J.
    north Alabama
    Cheaper than $500? Madtaco runs a mapecu3 and thats who suggested it to me, i had originally planned to go full ecu with a megasquirt3 but he and tor said that i wont need that much if im stayin under 9 psi and i dont ideally plan on internal upgrades so thats why i settled on this.
  12. Nov 7, 2016 at 5:31 PM
    #1612
    White Stripe
    White Stripe Member
    Ha ok darn. Im just really looking forward to seeing how it runs! Keep us posted.
  13. Nov 7, 2016 at 5:46 PM
    #1613
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I got mine used for $200 IIRC. New I think they go for just under $400.
    yota243[QUOTED] likes this.
  14. Nov 18, 2016 at 8:26 PM
    #1614
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    the aem fic6? i thought they are 600 new
  15. Nov 19, 2016 at 2:01 PM
    #1615
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  16. Nov 19, 2016 at 2:11 PM
    #1616
    yota243
    E.J.
    north Alabama
  17. Nov 19, 2016 at 3:06 PM
    #1617
    gray223
    SE Missouri
    2014 Tundra Limited
  18. Nov 19, 2016 at 3:13 PM
    #1618
    yota243
    E.J.
    north Alabama
    That song is really familiar haha. I hear u man well if u have a Christmas miracle and maybe a couple of ur friends do to, u no where to find me
    gray223[QUOTED] likes this.
  19. Jan 5, 2017 at 12:27 PM
    #1619
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Did you check valve your catch can Chris?
  20. Jan 6, 2017 at 6:26 PM
    #1620
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    What do you mean? I put a check valve on the rear vent for air to only go in. The PCV is a check valve that only lets air out. The catch can is just vented.
