Stange tin can/glass bottle clanging noise from drivers side front.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, May 20, 2013.
  1. May 20, 2013 at 5:54 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Hey all, im kinda spooked now. I just changed inner/outer tie rods (moog), both CV axles (oem toyota), inner axle seals/dust shields, and both upper and lower ball joints (moog)
    I had an alignment done and a lug centric balance.
    I now have this bizarre noise coming from the front end. It sounds like rolling a glass bottle on the pavement. Its freaking me out, because i did this stuff as preventative maintenance for my Moab trip next weekend.
    What the actual fuck
  2. May 21, 2013 at 9:07 AM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Ha, figured it out.
    My black axle hub/cover thing popped loose, and bounced around inside my inner toyota wheel cap, and the hub itself. (I mangled it a bit removing it to change the half axle)
    I freaked out a bit, because it sounded scary.
  3. May 23, 2013 at 2:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    glad you got it squared away. had that happen before.
