Star Toyota in Houston Changed Mind, TSB is Complete !
Discussion in '2nd Gen. Tacomas (2005-2015)' started by teri4lance, Jul 31, 2009.
  1. Jul 31, 2009 at 6:53 PM
    teri4lance
    teri4lance [OP] Well-Known Member
    SE Texas
    09 SR5 4x4
    Removed the price sticker in the window, bobbed 6" off the mudflaps, debadged. TSB completed.
    The dealership (Star Toyota near Houston) did the TSB on my '09 DC SR5. At first they refused and said I did not have a problem. I forwarded the thread I started here to them along with pictures of the sacked springs when I had about 600 lbs in the bed. About a week later I was called out of the blue by the parts guy who said my warranty parts were in. I had no idea, nobody ever called me. So anyway I made an appointment and they did the whole thing. I haven't driven it yet because I was out of town, but my wife says it drives a little firmer, almost like a truck!
    Thanks to everybody who read / responded to my original post. The dealership management looked at the post and I think it helped them change their mind. Especially when they saw the effect this kind bs has on current customers. Here is the op....
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/44839-south-houston-tsb.html
  2. Jul 31, 2009 at 7:41 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Congrats! That is very good news.
  3. Aug 1, 2009 at 6:36 AM
    ethanw
    ethanw Active Member
    Do I need to do this with my truck? Is brand new? How can I tell?
    Thanks guys
    Ethan
  4. Aug 1, 2009 at 11:35 AM
    teri4lance
    SE Texas
    09 SR5 4x4
    The TSB replaces the rear springs and all four shocks with ones that are more heavy duty. It is NOT a safety concern unless you haul big loads. The down side is it will ride more like a truck. The upside is it will be better for hauling heavy loads and/or trailers. It is useless if you are intending to do a full suspension lift front and rear as you will be replacing the parts anyway. Your truck has to qualify by vin,truck model, part number, and year (kinda). Print out and look at the tsb to see if you qualify. It is posted all over the place here. Good luck!
  5. Aug 1, 2009 at 11:44 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2 :woot:
  6. Aug 1, 2009 at 11:54 AM
    ethanw
    Thanks.. No plans to haul andy big stuff, but my V12 show car, other babe :) It weights around 4354 lb.... Will that be a problem?
  7. Aug 1, 2009 at 1:48 PM
    techgeekwill
    techgeekwill Captain Funk
    Spring, TX
    09 Tiberland Mica DC LB
    Sweet. I tried Joe Myers, but the SA and the Shop Supervisor said no way. It was a "common problem" and Toyota designed it that way. Whatever.
    Star is a little too far for me, but I'm going to try and see if I can get someone on the North Side to do it.
  8. Aug 1, 2009 at 8:42 PM
    teri4lance
    SE Texas
    09 SR5 4x4
    Ethan, you'll know the first time you tow. The rear suspension will probably hit the bump stops if you have the three leaf springs.
