STARR HID - anyone deal with them?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by normbal, Nov 20, 2009.
  1. Nov 20, 2009 at 9:31 AM
    normbal
    normbal [OP] Well-Known Member
    Norm
    socialist occupied Maryland
    White SR5 long bed
    minor mods. Hood moustache, truckchamp SS oval step-bars, Go Rhino Hitch step, popnlock plus tailgate hoseclamp, Weathertech digitalfit floor mats. Wheel and spare tire locks.
  2. Nov 20, 2009 at 9:34 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    I would call them about this... Those dont even look like they are made for the 05+ from the picture and they dont look like an OEM retro either. They look like an after market headlight. IN that case probably along the same quality lines as the ebay stuff. that could be had cheaper with a HID kit and IMHO look better.
  3. Nov 20, 2009 at 9:37 AM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Hey you can do alot better then that, I am not sure where to get the Euro style headlights since I havent done a search in a while. But I foung a comperable set for a little over 300 awhile ago. As far as the HID, slimcubby has a group buy on them about once a month for about $120. I would definately do a lot more research before you buy.
  4. Nov 20, 2009 at 9:43 AM
    normbal
    Norm
    White SR5 long bed
    That's what I'm doing HERE :)
    I ordered a set of H10s from DDM for my foglights (the stock ones are useless except to light up curbs a little) and am looking into options for the mains. The drop-in Bi-xenons have me a little worried about cops (MSP aren't customer-friendly and I commute at NIGHT), so I really want a projector set. Maybe.
    THanks.
  5. Nov 20, 2009 at 10:07 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    those are 01-04 taco headlights, will not fit your current gen taco.
    i am going to try to make a bolt on projector setup here in the coming months...keep an eye out for it!
  6. Nov 20, 2009 at 10:17 AM
    BIGLuke
    BIGLuke I'm a TW addict!
    Luke
    Chicago suburbs IL
    07 4X4 tacoma SR5 Double Cab Shortbed Speedwy
    Would you be able to let me know when that happens? I might be interested
  7. Nov 20, 2009 at 10:21 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    i will post it all over all the boards, dont worry...you'll see it!!
  8. Nov 20, 2009 at 11:17 AM
    PreRunnerSeth
    Apex, NC
    I love the light output of the Retros in the second gens. But, I just cant stand the looks. They just dont look right to me with that little projector in that big housing with just a shroud around them. In the coming months I *MIGHT* be doing a Q45 retro. :)
  9. Nov 20, 2009 at 11:23 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    those are those huge bug eye projectors right? w/ the 6 little lenses?
    if so, make sure you check the output pics of those BEFORE you spend the money and retro those....hint...not good output...! check HIDplanet.com/forums for a ton of output/retro pics...you can read more months there and still come across different ideas.
  10. Nov 20, 2009 at 11:35 AM
    PreRunnerSeth
    Apex, NC
    I've seen output pics of Q45 retros before and they output is fine. Maybe youre thinking of those knockoff Q45 retros you can buy on ebay.
  11. Nov 20, 2009 at 1:00 PM
    BIGLuke
    Luke
    Chicago suburbs IL
    K thanks I'll be waiting
  12. Nov 20, 2009 at 3:48 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    As stated above, those are for the first gen Tacomas.
    These are the kinds available for the 2nd gen Tacomas:
    Gen 1
    Gen 2
    Gen 3
    All you would need to complete them are some HIDs from either VVME.com or DDMTuning.com.
    All you would need is a complete single beam kit with size H1.
  13. Nov 20, 2009 at 8:11 PM
    normbal
    Norm
    White SR5 long bed
  14. Nov 20, 2009 at 9:39 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    yea, we know...DDM is the best, VVME is awesome...both are cheap and better than retros....its really getting old! (im not the only one...;))
    the OPs link is to a headlight that uses OEM projectors (E55s if i remember correctly?) and bulbs, unlike the 3 linked headlights that use inferior H1, etc bulbs. also, those aftermarket HID kits do not use D1S bulbs like linked in the original post, they used rebased aftermarket bulbs that have proven to run hotter and ruin chrome bowls and melt/burn OEM headlights.
    The linked headlights are in an entirely different league than the ones you posted.
    OP, the above headlights are not nearly as good as the ones posted for the 1st get. currently though, nothing like you posted is available for the 2nd gen tacos. i hope to change that in the coming months, but the only way to get what you linked to is to do a retrofit. see the link in my sig or HIDplanet.com/forums for more info. also, pm me if you need some help!
  15. Nov 20, 2009 at 9:42 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    yea, i checked, i am talking about the OEM Q45s, not the egay ones.
    search over on HIDplanet.com concerning these projectors...i have read that they cost a ton and put out decent light, but nothing compared to the TLs, S2000s, or FX35s...hope that helps, just trying to help you out from my readings in the past...
  16. Nov 20, 2009 at 10:14 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Those are for the 2nd gen Tacomas....
    I don't think you understood me correctly over on TN. The only thing I said that was better about a PnP HID kit (no projector) in stock housing is the brightness. I love going down dark roads and being able to see almost everything. Yes, I know projectors are better for all other reasons (hence my current setup and new project ;)).
    I think you're missing one small detail. Considering that he posted this thread in the '2nd Gen. Tacomas" section of the forum, I would think he has a 2nd Gen. Tacoma. His initial post was a link to a pair of headlights with projectors and HID kit for a 1st Gen. Tacoma. Also, seeing that he thought it was kind of 'pricey', I suggested some alternatives that are less expensive.
    No reason to get in a piss match.. again. You don't have to preach and gain followers. We do appreciate your info though.
    Cheers :cool:
  17. Nov 20, 2009 at 10:40 PM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Here we go again! :rolleyes: Do what you want bro, but please do thorough research before you buy and put anything into your truck. Retro's FTW! :D
    TN quote post #8 - http://www.toyotanation.com/forum/showthread.php?t=321883 :rolleyes:
    Have a great weekend all!
  18. Nov 21, 2009 at 7:20 AM
    normbal
    Norm
    White SR5 long bed
    "I think you're missing one small detail. Considering that he posted this thread in the '2nd Gen. Tacomas" section of the forum, I would think he has a 2nd Gen. Tacoma. His initial post was a link to a pair of headlights with projectors and HID kit for a 1st Gen. Tacoma. Also, seeing that he thought it was kind of 'pricey', I suggested some alternatives that are less expensive"
    Sorry to start a pissing match. I"m new to the forum. This is my first truck, after beating up several Volvos, Toyota vans and a Jeep with cement, brick, 2x4s, topsoil, play sand and every other damned thing I could pack in them.
    I don't think I realized there WAS a 2d generation (there's a third now?) Tacoma, and I hadn't looked at the glass/housing that carefully when I saw the STARR website.
    There seem to be some other options (thanks for the heads up on the eBay housing sales), I ordered some 35W 3000K HIDs from DDM for the fogs. AFter having HIDs on my Sienna (long gone, a victim of Toyota's recall of the week program) I really want better lighting (who doesn't?).
    Thanks (so far) for all the information and leads. With so much information posted here it's a lot like trying to find a needle in a stack of needles...
