Start-ability Malfunction 2012 Tacoma
Discussion in 'Technical Chat' started by MGMAddict, Feb 27, 2012.
  1. Feb 27, 2012 at 3:40 PM
    MGMAddict
    MGMAddict [OP] Well-Known Member
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    Hey guys just figured id ask on here to see if anyone is having starting issues with the new Tacoma's. I got the truck in the beginning of Jan and its probably done it about 15 times since.After extended sit periods ill go out to my truck and it will just crank and crack and not fire. Turn it over a second time and it starts right up. Im a technician for Lexus so I hooked up the tech stream and I found a P1604 code stored as a current code.Looked up the code on TAS and there are a ton of trouble areas to check. Glanced over the freeze frame data and nothing seemed out of the ordinary. Id like to fix it myself and not have our toyota store throw parts at it, i just didn't have much time to check it out today.
    MechanicOfThings likes this.
  2. Feb 27, 2012 at 3:43 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    My '05 does this on occasion.
    What I've been doing lately is turning the key to on, without starting, while I organize my phone and wallet and put the safety belt on, then starting the truck, that way the fuel pump has time to get going. Seems to be working.
  3. Feb 27, 2012 at 3:50 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I do the same thing......turn key on and let fuel pump work for a sec, until i hear it stop. I've had my 2012 since Jan and so far (knock on wood) I haven't had any starting problems
  4. Feb 27, 2012 at 3:54 PM
    MGMAddict
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    i understand the fuel pump needs to cycle I just never had to do this on my 2009 tacoma
  5. Feb 29, 2012 at 8:33 PM
    Rmesa1
    Rmesa1 Well-Known Member
    P1604 sets anytime the engine cranks and does not start. It will also set if the truck stalls. Haven't seen any starting issues on the 2012s I'm a Toyota tech myself I will check with my fts and see if he as heard anything
  6. Feb 29, 2012 at 8:38 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Ive read on here theres a tsb for extended crank..reflash the computer will take care of that. On my 05, i just turn the key wait a second then start..something to do with the engine immobilizer
  7. Feb 29, 2012 at 8:48 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My 07 had the same issue...took it in after owning only 2 weeks and they did a reflash to fix the problem. It's started right up ever since...no waiting with the key.
    TSB EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
  8. Mar 1, 2012 at 6:19 PM
    MGMAddict
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    I saw the service bulletin for the old tacoma int. no start but when I hook up the scan tool the only ecu update is the one for the supercharger mapping. Ive been letting the key cycle for a bit longer and it hasn't happened yet. I just don't see why you shouldn't be able to get in and start it up....Dumb.
  9. Mar 1, 2012 at 6:23 PM
    Rmesa1
    From what I have heard on a cold start where the temp changes a lot from when the car is started to when it was turned off it can take a little while longer for the ecu to adjust the fuel trim to the correct settings for the current temps of the coolant and intake air.
  10. Mar 1, 2012 at 6:28 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... Sub'd ... :popcorn:
  11. Mar 2, 2012 at 11:42 AM
    MGMAddict
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    yeah see thats the thing though, my freeze frame data was all where it needed to be correctly to start, AF's IAT Coolant temp
  12. Mar 2, 2012 at 11:45 AM
    MGMAddict
    Doylestown,PA
    TRD Sport
    Bilstein ULC
    Lets keep in mind too its done is on 20 degree days and 65 degree days. Tried swapping keys figuring maybe it was immobilizer issues but it still does it with both keys.
  13. Mar 8, 2012 at 1:15 PM
    J Veezy
    J Veezy Active Member
    Jeff
    Seattle, WA
    '12 SW TRD-S DCLB
    I haven't this issue at all on my 2012, but on my 07 I did. I had a widget that let me play music off an iPod with the stock head by pluggin into the changer port. Every so often, it would get confused and stop working so I'd have to disconnect the battery for a few seconds to reboot it.
    Every time, without fail, the engine would turn and turn without firing right after. The second attempt fired it right up. I never really thought of it as a problem so I didn't look into it. It may be completely unrelated (I assumed it had to do with the ECU rebooting or winding the fuel pump), but thought it could help your diagnosis.
  14. Mar 8, 2012 at 1:22 PM
    hpvds
    hpvds Well-Known Member
    Manie
    Seattle, WA
    Barcelona Red 2010 4x4 Doublecab
    Ironman 4x4 FCP lift, ARB bumper, NL Dual bats, Skids and sliders
    My 2010 has been doing this recently for about the past week and a half or so. Also last winter there were a few times where it would either not crank or crank for 5+ seconds and nothing would happen. It was extremely intermittent and would occur randomly and did not seem to be related to temperature.
  15. Mar 8, 2012 at 4:01 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    The check ball in fuel pump is only so good at holding pressure in the rail.
    Keying up the vehicle and allowing it to fully prime the rails and reach proper pressure is the reason it works on the second try.
    Most just live with it since the pump still works and it is a decent amount of work to change the pump for just this.
    Dealer will not warranty the pump for this issue.
  16. May 16, 2013 at 9:25 PM
    PitAlain
    PitAlain New Member
    Alain
    Canada
    Toyota Tacome TRD 2012
    had my toyota tacoma 2012 since last june and had trouble starting since almost the day i got it,went to the toyota garage for about four to 5 times and the error p1604 was popping every time the only thing that they could tell me is that there was water in my gas and had to put a little can of stuff to remove the water from the systeme that toyota sell with their brand name on it how weird,i hope it will work cause my truck is brand new and i'm sick and tired of toyota right now.
  17. Dec 19, 2014 at 5:43 PM
    Willcory
    Willcory Well-Known Member
    San Antonio TX
    2013 Black Tacoma 4x4
    I have the same problem but mine is a '13.. I dont get a p1604 it just wont start or will cut off on me while driving. it has happened 4 times now the last time they said they founda loose connector.
  18. Dec 19, 2014 at 6:07 PM
    gearcruncher
    Canadain bumper technician
    This is an excellent point ^^^^^
    Is there a transducer in the Tacoma ecu that shows fuel pressure on the scanner at start up ?
    Ive been having similar issues . I suppose it would be just as easy to do a leak down test on the fuel rail with a pressure guage first thing in the morning but as I understand it , the fuel pump primes the fuel rail when the engine cranks over to satisfy the PR valve which provides the fuel to the injectors . If the checkball is leaking , is there a modification we can do
    Edit : I beleive this is why my command start has been giving me greif
  19. Dec 20, 2014 at 9:38 AM
    53wick
    53wick Well-Known Member
    kentucky
    2014 accesscab prerunner
    my 2014 did it several times last winter when I got it. I cant hear my fuel pump running, I turn key on wait for fuel gauge to come up then start. it just did it again this week, cant remember if I turned key on before gauge came up. but when it does not start, the second time I try to start, when it does start it acts like the engine is flooded. reminds me of years ago with cars with a carburetor.
  20. Dec 20, 2014 at 9:44 AM
    Mr Ribby
    Mr Ribby Well-Known Member
    Andrew
    NW Indiana
    2013 "Baja"
    Pioneer DvD double din, pioneer 5way front door speakers, kicker 3 way rear door speaker
    My 2013 did this to me yesterday, sat for about a day an half at temperatures below 20 degrees. Turned key cranked about 5 times. I stopped let it sit for about 20 sec, then gave it another go and started on next 2 turns. I'm not very mechanically inclined, but could this be a combination of the fuel system and the new smog systems they have added? Hopefully someone can find a solution
