Start button dead
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Eldonw, Mar 9, 2025.
  1. Mar 9, 2025 at 1:20 PM
    Eldonw
    Eldonw [OP] Member
    Eldon
    2021 Taco trd pro
    I just installed a driveshaft disconnect so I can flat tow the Taco. It all checked out ok and worked fine. I then turned off the truck and went to install the steering wheel fuse bypass switch under the dash. I removed the correct fuse, inserted the bypass adapter then started to look for a place to mount the switch under the dash. As I was moving the switch around I bumped it on a metal bracket and it sparked. I stopped there and checked the inline fuse, all was good. I tried to start the truck but got no response from the start button. I removed the swith and reinstalled the good fuse and tried again but still no response. I checked every fuse in that panel and the ones I could check under the hood. All fuses are good. The remote also will now not lock/unlock the doors. The door ajar light and hood open light will come on and headlights and horn work but nothing else seems to have power. The truck is in park but the steering wheel is unlocked. I disconnected the battery and let it set for a bit, hoping it would reset but it hasn’t. Has anyone had experience in this area.
  2. Mar 9, 2025 at 1:36 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    How are you checking the fuses? A visual inspection is not sufficient. You will want to continuity test them. They may look good but are not...
    Chew likes this.
  3. Mar 9, 2025 at 1:54 PM
    Eldonw
    Eldonw [OP] Member
    Eldon
    2021 Taco trd pro
    I pulled them out one by one to check them.
  4. Mar 9, 2025 at 2:16 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Next time undo the battery. FIRST!
    shakerhood, auskip07 and Chew like this.
  5. Mar 9, 2025 at 2:32 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Looks like you have fried either wires or BCM (Body Control Module).
    Maybe ECU... not sure.
  6. Mar 9, 2025 at 2:56 PM
    Eldonw
    Eldonw [OP] Member
    Eldon
    2021 Taco trd pro
    That’s what I’m thinking. The unlock buttons on the door do not work either. I tried putting the remote up to the button but that didnt work either. You would think it would have blown the fuse before doing any further damage.
  7. Mar 9, 2025 at 3:06 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    Did you check the pulled fuses with a meter to make sure they have continuity? As stated above, looking at the fuses is not enough.
  8. Mar 9, 2025 at 4:32 PM
    Eldonw
    Eldonw [OP] Member
    Eldon
    2021 Taco trd pro
    I will tomorrow. I loaned out my multimeter to dad. Gotta go repossess it.
    Bertw192 and kent50 like this.
  9. Mar 9, 2025 at 6:17 PM
    kent50
    Kent
    It may not be the issue but always start with the cheapest and easiest first. Good luck!
    Bertw192 likes this.
  10. Mar 10, 2025 at 3:25 PM
    Eldonw
    Eldonw [OP] Member
    Eldon
    2021 Taco trd pro
    Resolved! It was a 50a fuse under the hood! Now the steering lock bypass is installed (with the battery disconnected) and everything is working properly.
  11. Mar 10, 2025 at 7:16 PM
    Bigmatt503
    Bigmatt503 Well-Known Member
    Nice work!! Thanks for updating us
    Barsoom and Chew like this.
