Start up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nate15, Apr 27, 2017.
  1. Apr 30, 2017 at 11:48 AM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    I would have the injectors cleaned at the dealer, cause they have the adapters needed to tie into the fuel line to clean the injectors.. Usually runs around $~90
  2. Apr 30, 2017 at 12:11 PM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    It's possible that you have just one injector that is leaking/occasionally sticking. Rather than having the dealership clean the injectors, it might be worth using that money to have them diagnose it. We do the injector cleaning service at the Ford dealership I work at, but I'm not really convinced it does much, especially if there's already a problem. Just my opinion.
  3. Apr 30, 2017 at 5:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Does your oil smell like fuel? Maybe pull the plugs
  4. May 1, 2017 at 1:50 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    About all that can be done is run some Techtron Fuel additive through the gas tank. If you have a leaking injector or it is sticking open or closed the only option is a replacement.
  5. May 1, 2017 at 9:56 AM
    Nate15
    Nate15 [OP] Active Member
    Nate
    Salt Lake City, UT
    07 Silver
    Thanks for the help guys. I'll try the techron additive and go from there.
  6. May 6, 2017 at 10:00 AM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Update?
  7. May 6, 2017 at 12:08 PM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    My truck does the same mostly when its warmed up, work at a dealership going to do a injector flush here in a little bit to see if it fixes my issue.
  8. May 6, 2017 at 7:50 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Injectors are assembled in a clean room environment. There is a 1 micron mesh filter in the inlet to the injector. There is also usually a 1 micron internal filter also. How are you going to flush anything out if there is something inside anyway. Easy answer is - you aren't. At best a product such as Techron or Seafoam will clean the external orifice plate holes on the outside of the injector.
  9. May 6, 2017 at 8:20 PM
    OKTACO
    Ty
    2005 SR5 Taco
    Good question, however running cleaner through the injectors has seemed to improve the situation.
