Start-X Remote starter
Discussion in 'Product Reviews' started by Yoda_Mike, Apr 4, 2023.
  1. Feb 13, 2024 at 4:55 AM
    RUSTY58
    RUSTY58 New Member
    2020 Mag.Grey TRD Off Road 4x4
    Just installed the updated 2020-2023 Start X + PTS kit on my Tacoma 2020 TRD Off Road. Straight forward installation. Comes with hood switch that I opted not to install. TPS monitor still works after installation. Tip: Take a picture of Service # on back of remote module before install. They will ask for it for on-line questions. I found it easier to plug in long thin connector from T-harness to vehicle first then connect to module. Makes wire management and routing less of a struggle. Runtime is fixed at 15 minutes and can not be changed. Works as described. Overall happy with product.
  2. Mar 21, 2024 at 11:21 AM
    SkinsNation
    SkinsNation New Member
    Has anyone had any trouble out of the H-key remote start kit?
    It’s a super easy install, but I can’t get it to program. They have sent me a whole other kit. I can get to where the blue and red lights flash 9 times, pause and keep repeating that. Next is to insert the key and turn 2 clicks to ON and wait for it to program, that’s where it stops, and he blue and red lights go off and it never connects.
    Remote Start X support had me try all kinds of different t ways. Moved the ground, checked comnections, it just won’t go past that step. I’ve tried with wires plugged into module, tried plugging the power in first, all while holding the button. I’ve watched every video I can find with push start and H-key. Anyone had this issue?
  3. Apr 8, 2024 at 6:10 AM
    yellowtop1
    yellowtop1 Well-Known Member
    Need one.
  4. Apr 18, 2024 at 11:45 PM
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    I had this issue. Did you splice your tpms wire (pink or green) to the butt connectors that attach to the remote start unit? I had a bad crimp job and had to redo it my first time. Also make sure you really follow the instructions. If it fails do the reset. Unplug everything. Reconnect everything and do power last connection last? I believe
