Started changing the brake shoes and...
Discussion in '4 Cylinder' started by kodiakisland, Mar 24, 2020.
  1. Mar 24, 2020 at 2:01 PM
    kodiakisland
    kodiakisland [OP] Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Taking advantage of a week at home. Truck has 115K miles on it, so I changed the spark plugs and brake shoes/pads. Decided not to change the shoes as they were at least 3/4 as thick as the new ones. Front pads would have probably gone to 150K, but they’re easy to change. Only one of they plugs looked like it needed replacing.
    Amazing how little maintenance these trucks need to stay on the road.
    BillsSR5 likes this.
  2. Mar 24, 2020 at 2:08 PM
    theick
    theick Well-Known Member
    Eric
    Las Vegas
    Since you're feeling chippy don't forget the brake fluid, antifreeze and all the gear oils.
  3. Mar 24, 2020 at 3:03 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Gear oils get changed on a regular basis, even though they probably don't need it. Again, these trucks can run forever on very little maintenance.
    Those who never owned and operated a vehicle from the 60-70s don't know how lucky they are.
  4. Mar 24, 2020 at 8:22 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    My front brakes lasted till 145K, back were changed around 165K only because I had an axle seal that required replacement.
  5. Mar 25, 2020 at 8:03 AM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    It’s amazing how long they last, and maybe that’s part of the reason why the Tacoma is held in high regard, even by people who aren’t “car” people.
    I can remember vehicles that had to have brakes every 30-60K miles, and not performance cars. Plugs every 30K. I can even remember changing points and distributor caps. Maintenance used to be a chore and if you didn’t do it the vehicle stopped running. I think a Tacoma would run until it rusted out with only an occasional oil change.
    Fast1, kjttaco and BillsSR5 like this.
  6. Mar 25, 2020 at 1:27 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    So I'm not the only one on TW "I can even remember changing points and distributor caps."
    kjttaco likes this.
  7. Mar 25, 2020 at 1:31 PM
    george3
    New Jersey
    how hard is it to do the axle seal ? Thanks for any reply and or info.
  8. Mar 25, 2020 at 4:35 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    seems crazy now.
  9. Mar 25, 2020 at 7:17 PM
    Fast1
    Minneapolis, MN
    I had the stealership do it since I was lacking the proper tools and time. If I remember correctly, there are several seals on each side and the axle must be completely removed to get to both for exchange. Also, since it was leaking fluid I had to replace the old oil soaked rear pads. Now as I think about it, I believe I also had the bearing replaced too since the leaking lubricant was contaminating the bearing.. was approximately $500 for the seals/bearing
    quick overview here..although it is a 4runner but almost identical process
    https://www.youtube.com/watch?v=AVhSDnw2ugo&list=RDCMUC9EMiD9KPy61kJ6hdXcbjxA&start_radio=1&t=0
