starter about to go bad?
Discussion in 'Technical Chat' started by achirdo, Feb 24, 2011.
  1. Feb 24, 2011 at 12:29 PM
    achirdo
    achirdo [OP] I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i got an 05 V6 and everyone once in a while maybe once everyday ill try and start the truck and it wont turn over but then as soon as i turn the key again it kicks right over only alot faster than it normally would.
    it goes *turns key* ta ta ta ta ta ta ta ta ta ta ta ta ta ta
    *turns key again* ta ta vroooom
    (excuse my brillant impersination of my truck starting noises:D)
    does this mean that my starter is starting to go bad? or is there something else i should look at?
  2. Feb 24, 2011 at 12:31 PM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    so it DOES turn over on the first try...it just doesn't fire up and run? mine does the same thing sometimes....turns over for what seems to be longer than normal but does not fire. I'll stop...try again, it turns over and fires up. Not sure what the issue is, but I'd be interested to find out if others have the same issue.
  3. Feb 24, 2011 at 12:33 PM
    achirdo
    Adam
    North DFW
    yup thats pretty much it. just a lil wierd to me that it doesnt fire up right away. just started doing it recently. battery and alternator are both fine
  4. Feb 24, 2011 at 12:37 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    If the starter were going bad it wouldn't try to turn over. Sounds like a fuel delivery, spark, or battery issue to me.
  5. Feb 24, 2011 at 12:38 PM
    achirdo
    Adam
    North DFW
    hmm this sounds like a job for....CHRIS4X2
  6. Feb 24, 2011 at 12:45 PM
    ds46000
    yeah, my battery and starter are fine...i agree w/ the fuel delivery or spark issue.
    my guess has always been fuel pump...almost like it doesn't start pumping soon enough on startup.
    i always mean to try turning the key to the run position and wait a sec before engaging the starter (perhaps giving the fuel pump a head start), but i always forget.
  7. Feb 24, 2011 at 4:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Toyota had a TSB for this issue, but Im sure your out of the TSB window. Are any codes being thrown by the CEL?
  8. Feb 24, 2011 at 5:10 PM
    ds46000
    yeah, looks like me and the OP are both past the warranty.
    Chris, Do you recall what all was involved w/ the TSB? What was the cause, and what was the fix?
    And, I do not know if any codes are being thrown, but I'd guess if there were, the maintenance light would be coming on? If that's the case, I personally do not have any codes being thrown, as my maintenance light isn't coming on.
  9. Feb 24, 2011 at 6:35 PM
    achirdo
    Adam
    North DFW
    Yeah I'm out of the TSB range. Havnt checked for codes I'll go to autozone or something tomorrow. Do you remember what the TSB involved doing?
  10. Feb 24, 2011 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The TSB involved a re flash of the computer....
  11. Feb 24, 2011 at 9:10 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    shouldn't be that expensive to get it flashed. I'm sure it'd be a little bit. WAG, 200 bucks, unless they wanted to do a diagnosis first.
  12. Feb 24, 2011 at 9:29 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    mine does that sometimes when i just jump in and hit the starter.
    I usually try to turn the key "on" for a few seconds before trying to crank, letting the fuel filter run for a second. Ive never had it not crank when doing that. its only when im in a hurry that i forget to do this and sometimes it wont start
  13. Feb 24, 2011 at 9:33 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Are you sure the engine is rotating the first time? Low voltage to the starter will cause the solenoid to chatter. I'd check battery and connections first if that's what's happening. Have someone watch and see if the engine is actually rotating.
  14. Feb 24, 2011 at 9:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I think the TSB Chris is talking about is for rotating engine, but no spark, fuel,etc. Turn key off, then back on and to start and it fires right up. Mine's done this once (on vacation in the middle of nowhere), never again since. If I remember right the TSB applies during the emission warranty. You may still have coverage. But make sure the engine is actually turning over. Your description makes me wonder.
  15. Feb 24, 2011 at 9:38 PM
    achirdo
    Adam
    North DFW
    Yeah it will start fine on the 2nd key turn. And also starts alot faster than normal on the second key turn
  16. Feb 24, 2011 at 9:49 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Check your warranty info. The TSB should be covered under emissions. I know mine is seven years, but I'm in California and we have longer emissions warranty.
    I was going to have mine done, but it only happened once and I hate to have Toyota F--- with it while it's running correctly
  17. Feb 24, 2011 at 9:56 PM
    island808
    Jedediah
    hawaii
    True... state laws and warranty. YMMV
    If its not turning the first time. That's a bad wire or terminal. If its as it sounds it's described. Many many reasons for that. First I would check is tank lock. Take off the gas cap when I park it, leave it loose over night, see if it happens the next morning. Clogged vent can cause a vacuum in the tank and draw back gas, cause fuel pump strain.
  18. Feb 25, 2011 at 5:35 AM
    achirdo
    Adam
    North DFW
    Yeah Im not a fan of letting Toyota mess with it either. And I really don't want them messin with the ecu and all there stupid reflashes b/c of the non nonexistent sticking accelerator
  19. Feb 25, 2011 at 5:58 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  20. Feb 25, 2011 at 8:55 AM
    island808
    Jedediah
    hawaii
    well you're in luck they don't do that.
