Starter Battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Feb 3, 2010.
  1. Feb 3, 2010 at 12:30 PM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    2oo5 pre-runner battery finally kicked it. Cold weather, age, new alarm/starter, amps, and I tow a travel trailer didn't help. Plus I leave it sitting for 2-3 mnths alone. Which is why I am here asking your advise. I can't afford to have the thing not start or have a charge for the alarm to protect it. So money is no problem for a battery. Question is which one???
    found a optima yellow for above application.
    Would going with 1000 CCA be better then the 700 one?
    Does size matter? ( I can make it fit somehow)
    What price did you get yours for? I am finding $200 bucks for one...This sounds crazy since it would be about double the price for a good convention one.
    Any ideas?
    Thanks
  2. Feb 3, 2010 at 1:05 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
  3. Feb 3, 2010 at 1:20 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    optima batteries are the way to go, they are double the price because they last and have a decent warranty. generally they higher the cca the thinner the plates (or in an optima's case spiral wrap sheets) inside the battery are. they give you a better kick when starting at cold temps but don't last as long.
