starter click..
Discussion in '1st Gen. Tacomas (1995-2004)' started by wildjerseyfirefighter, Jul 2, 2009.
  1. Jul 2, 2009 at 4:25 PM
    wildjerseyfirefighter [OP] I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    well, its been happening for a while, but I thought it was just the battery..bought a new optima, and installed tonight..no differnce..the chiltons is a joke for starter remove/install..can anyone tell me how do to it?:mad:
  2. Jul 2, 2009 at 4:38 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    ill go get my haynes manual & post up what it says!
  3. Jul 2, 2009 at 4:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  4. Jul 2, 2009 at 4:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check your grounds, and make sure all connections are good before you condem the starter. :)
  5. Jul 2, 2009 at 4:48 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    1)detach the cable from the negative terminal of the battery. Caution: if the stereo in your vehicle is equipped with an anti-theft system, make sure you have the correct activation code before disconnecting the battery.
    2)raise the front of the vehicle & support it on jackstands.
    3)detach the electrical connectors from the starter/solenoid assembly.
    4)remove the starter motor mounting bolts.
    5)remove the bracket from the upper section of the starter/solenoid assembly.
    note:on 4WD models, it may be necessary to remove the front wheel & fender liner & access the starter motor through the opening.
    sorry it took me so long.
  6. Jul 2, 2009 at 6:11 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    where are the bolts? I kinda half assed looked, and couldnt find them earlier tonight. They go throu the rear of the bellhousing?
  7. Jul 2, 2009 at 6:16 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    yupp they go thru the bell housing
    there hard to get to unless ya have a body lift
  8. Jul 2, 2009 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Follow the large + wire to the starter. The bots go thru the rear.
  9. Jul 2, 2009 at 6:23 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    damn..sounds like a pain in the ass:rolleyes:
  10. Jul 2, 2009 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not that bad... Take your time.
  11. Jul 2, 2009 at 6:29 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    come over and lend a hand all mighty one:spy:
  12. Jul 2, 2009 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would, Buddy, if you were in the same state. :eek:
  13. Jul 2, 2009 at 6:33 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    haha..dang.:p
  14. Jul 3, 2009 at 10:47 AM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    well..got the old one out, and the new one in. From start to finish, and 2 trips to the parts store, it took me about 3 hours with the help of my dad. Starts just fine now, thanks everyone who lent a hand..er..typed some help.
  15. Jul 3, 2009 at 11:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! Told ya it wasnt that bad. :)
  16. Jul 3, 2009 at 8:24 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    the hardest part about doing the job, was trying to figure out how to get the damn plug off the starter. Everything else was cake.
