Starter clicks, transmission not engaging, checked linkage, still won't start
Discussion in '1st Gen. Tacomas (1995-2004)' started by shrkfud, Oct 5, 2023.
  1. Oct 5, 2023 at 8:27 AM
    shrkfud
    shrkfud [OP] New Member
    2003 Tacoma
    OME front suspension and rear, ARB front, tundra rotors and calipers
    Truck starter clicks, battery, cables good. Replaced starter, same click. Will not start in Neutral. Move out of park and all gears will not engage, truck auto transmission is not engaging, neutral in all positions, but park. Tried starting while moving shifter nothing, shifter will go through gears easy. Checked linkage all good. Why will truck not go in rev,drive etc. too start?
  2. Oct 5, 2023 at 11:34 AM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I'm sorry, the post is a little confusing. Are you trying to start it with the automatic transmission in gear? Are you saying when the truck is started none of the gear positions function?
  3. Oct 5, 2023 at 12:56 PM
    shrkfud
    2003 Tacoma
    No, I try to start in park P or in neutral N. But when I moved from P to N my truck rolled a bit. I thought not supposed to do that. So then I moved it to D drive, L low etc, I found out that it's in Neutral in all gears, there are no gears. The transmission is not letting the gears engage. Hence no start just the solenoid click and nothing turning to start truck.
  4. Oct 5, 2023 at 1:26 PM
    Gen1andDone
    There is nothing abnormal about your truck rolling when the engine is off, and the transmission is not in Park. The click you are hearing when attempting to start would lead me to believe it is something in the starting system. You have checked and verified that the battery, battery cables, and starter are all good, so I can't think of any other suggestions at the moment. I'm guessing you tried starting with a jump box or jumper cables?
  5. Oct 5, 2023 at 2:44 PM
    shrkfud
    2003 Tacoma
    So you saying the the truck will roll back quite a ways (20ft +) and forth in drive and reverse even though it's not neutral. Yep ,even had it on a charger. Battery good and cables ,even cleaned all connectors including transmission.
  6. Oct 5, 2023 at 3:05 PM
    shrkfud
    2003 Tacoma
    Wow, it was my new battery,disconnected from battery and plugged into portable power pack and started. Man who would have thought. New battery would do that.
  7. Oct 5, 2023 at 3:09 PM
    Glamisman
    Glamisman Well-Known Member
    Have you checked the trans fluid level?
  8. Oct 5, 2023 at 4:29 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Glad you fixed it, new parts being a dud isn't uncommon.
    SpokeWench likes this.
  9. Oct 5, 2023 at 4:34 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is the new battery really bad, or might it have not been properly connected? IE have you had it load tested?
    Your description of trans behavior is normal.
  10. Oct 5, 2023 at 4:57 PM
    gearcruncher
    Canadain bumper technician
    Confusing post .....had to jump in and have a look .
