Starter Going Bad
Discussion in '1st Gen. Tacomas (1995-2004)' started by ttran, May 23, 2012.
  1. May 23, 2012 at 6:19 AM
    ttran
    ttran [OP] Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    I have a 98 4runner which has the same 3.4 5vz engine as the Tacomas so I figured I'd post in here due to more traffic. As the title states, my starter is going bad and I'm trying to find the most cost efficient replacement. What would you guys do? Get one from the dealer, or do you know of someplace else? Seeing that the current starter already has 260k miles on it, I'd rather just replace the whole unit with a new one.
  2. May 23, 2012 at 8:35 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    You can go to toyota and buy just the contacts. They are probably the culprit. Much cheaper than a replacement starter.
  3. May 23, 2012 at 10:56 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Im not sure whats exactly broken inside it. When I crank it it makes a really bad grinding and cracking sound but it still starts everytime nonetheless.
  4. May 23, 2012 at 12:19 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Hope you haven't knocked teeth off the flywheel, could be a weak bendix also.
  5. May 23, 2012 at 12:37 PM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    I pulled the inspection plate off to look at the flex plate and it looks fine.
  6. May 23, 2012 at 2:14 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Tim, you can get your starter rebuilt by a local company that does that sort of repair. Use you phone book or ask people who have used the services of a rebuilder. Your armature is probably worn out, the starter bushings are worn out and the brushes need replacing, and your starter bendix is worn out after 260 k. These pieces are all out there if you want to keep your original starter. OR
    I am sure he will have a rebuilt one that is identical to your original. You can either route, if he rebuilds yours, it can take a few days or you can walk out the door with a rebuilt. The option is up to you. Good Luck.
  7. May 24, 2012 at 6:08 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    From what I understand that starter is a job to R/R so I'd want a quality rebuild starter and only do the job one time.
  8. May 24, 2012 at 9:53 AM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    Let me check my warehouse. Might have a new one I can send you for like thirty bucks or so, if you're interested. We get pretty awesome discounts on parts.
    Automatic or manual?
  9. May 24, 2012 at 11:02 AM
    ttran
    Tim
    Cary, NC
    TRD Sport Prerunner
    Ooh sounds good, automatic. Let me know! Thanks
  10. May 25, 2012 at 5:33 AM
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Sure will. Let me get to work in about an hour or so and I'll post back up with whether we have one or not.
  11. May 25, 2012 at 1:04 PM
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Okay, I looked all over and we have a ton of starters and alts, but we don't have the specific Remy number you use. Sorry man.
