Starter going bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by radtcma, Nov 16, 2009.
  1. Nov 16, 2009 at 4:49 PM
    radtcma
    radtcma [OP] Well-Known Member
    Portsmouth, VA
    01 DubCab 4x4 Lifted and Blown
    TRD blower, URD fuel kit, 6" Fabtech, 33x12.50 Nitto Terra Grapplers
    I've got an 01 DubCab with 141,000+ miles on it. When I start it, it clicks, then after half second to a second later it starts. Is this a start going bad? If so, how hard is it to change? If not, what else could it be? The battery is still pulling a constant 12-13 volts with the truck running and not running. Any help would be appreciated, thanks
  2. Nov 16, 2009 at 4:54 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yes, it sounds like the contacts are starting to go. They are replaceable and a cheaper fix then getting a new starter. Either way the starter will need removed. You will have to disassemble the starter to replace the contacts.
  3. Nov 16, 2009 at 5:05 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    Yea taking out the starter is pretty easy. 2 or 3 mounting bolts accesible through the wheel well
  4. Nov 16, 2009 at 11:40 PM
    Chris D.
    Chris D. Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    If you have a Fleet Farm store near you, they sell the full
    rebuild kits with new plunger and contacts for about 6 bucks..
    its a very common Nippondenso starter used on tons of other vehicles.
