Starter Issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Banjo-Paul, Dec 10, 2019.
  1. Dec 10, 2019 at 8:30 AM
    Banjo-Paul
    Banjo-Paul [OP] Member
    Paul
    2005 TRD Off Road
    Hey everyone,
    I have an ‘05 TRD and have had problems with it starting lately. Randomly the engine will not turn over but the all lights in the dash/radio turn on. The truck won’t start for 2 days, then it starts just fine for a few days, then back to not starting... I took a video of what I’m talking about and will try to post it here.
    I’ve got 255K Miles on the engine and have never had any major issues. I really want to figure this out As I love this truck!
    Maybe just a starter?
    I appreciate any advice.
  2. Dec 10, 2019 at 8:31 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How strong is your battery?
    whatstcp likes this.
  3. Dec 10, 2019 at 8:34 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Sorry to hear about your troubles....I would check the solenoid on the starter. Had the same problem with my 1st gen with the same complaint you're having. Once replaced the truck worked fine....
    Good Luck - keep us all posted!
    TheDevilYouLove likes this.
  4. Dec 10, 2019 at 9:11 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    The starter is a pain to remove, so if you need to take it out to diagnose something I’d just replace it. At least on the 4.0 4x4.
  5. Dec 10, 2019 at 9:22 AM
    Banjo-Paul
    Paul
    2005 TRD Off Road
    Thanks for the advice! The video would not upload to this post.
    I did the ‘aggressive’ cleaning of the battery terminals and did not fix the issue. Leaning towards just replacing the starter as the next solution...
    thanks again everyone!
  6. Dec 10, 2019 at 9:46 AM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    Replace starter or try one of the rebuild kits? Looks simple enough and tons cheaper. At least give it some consideration.
  7. Dec 10, 2019 at 10:46 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  8. Dec 10, 2019 at 8:32 PM
    B Dog
    B Dog Active Member
    Barry
    Eugene, Or
    2009 silver Tacoma PreRunner Double Cab
    I had a 1995 T100 that had a similar problem. It turns out that it was the safety switch on the automatic transmission. I had it replaced and that solved it. I’m not sure if this would be the issue you’re having, but it is something to take a look at.
  9. Dec 11, 2019 at 1:56 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you hear a single click then nothing it is probably the starter solenoid.
    You can rebuild the starter solenoid for about 35 dollars and an hour of your time.
    You can buy the contacts and plunger new from Nations Starter and Alternator for about 30 - 35 bucks. Much cheaper than hundreds for a rebuilt POS from Autozone etc.
    https://www.nationsstarteralternator.com/Starter-Rebuild-Kits-s/37.htm
    Check this video for rebuilding the solenoid on the starter.
    https://www.youtube.com/watch?v=qwokxzjlYcQ
  10. Dec 11, 2019 at 4:18 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Great info/video Jimmy.
