Starter issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brogie, Jun 20, 2024.
  1. Jun 20, 2024 at 8:40 AM
    Brogie
    Brogie [OP] Well-Known Member
    Mark
    Columbus, OH
    2014 4wd standard cab silver sky
    Went out to start truck this am (2014 standard cab 4wd auto 107000 mi). Cranked a couple of times sluggishly then that rat a tat sound and no action. Checked battery with meter, (showing 12.3 v), lights, horn, radio all operate fine. Loosened and moved clamps on battery and retightened, still no dice. Any insight is appreciated. TIA
  2. Jun 20, 2024 at 8:48 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like a dead battery, what's your battery voltage while cranking?
  3. Jun 20, 2024 at 8:55 AM
    Brogie
    Mark
    Columbus, OH
    That's exactly what I thought, but am reading 12.3 v at battery and all other functions are fine. I not getting any cranking just rat a tat (just like a dead battery).
  4. Jun 20, 2024 at 8:57 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    12.3v with no load on the battery doesn't mean much, see what it drops to when you try to crank it.
    If it goes less than about 9.5v your battery is either bad or dead.
    kidthatsirish likes this.
  5. Jun 20, 2024 at 8:59 AM
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    Bear in mind, there are 2 factors to consider with a battery when starting an engine - voltage and amperage. A battery can read fine on a volt-meter at rest but still be failing because it lacks sufficient amperage to deliver that voltage to the starter. The issue you describe sounds like exactly this. You can test by attempting to jump start it. If that works, the battery is failing.
  6. Jun 20, 2024 at 9:20 AM
    Brogie
    Mark
    Columbus, OH
    Indeed. My wife got home and upon cranking it dropped to 6-7v. I am ordering a battery now. Thanks
    Dm93, SR-71A and Steves104x4 like this.
  7. Jun 20, 2024 at 9:28 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m going to ask a dumb question but when your truck is idling, does the tachometer needle bounce a little bit or is it steady?
  8. Jun 20, 2024 at 12:22 PM
    Brogie
    Mark
    Columbus, OH
    Steady, and I checked alternator output with new battery and got a steady 14v. So the alternator is okay. Thanks for the help from everybody.
