Starter motor intermittent failure, one more time please?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Apr 6, 2020.
  1. Apr 9, 2020 at 4:13 PM
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
    If your arms can't reach that far down to the starter then hopefully you can reach in your back pocket for some cash to pay a mechanic.
  2. Apr 9, 2020 at 9:24 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Weather permitting or the situation, I'm resigned to keeping a broom handle on hand when it happens again. I'll poke and prod the solenoid area and starter and see if the starter cranks. If it does, I'll be relieved that I've determined I need to replace the starter motor, solenoid and all. Paying a garage to clean the contacts or such will require enough labor cost to get at it, that that money would be better spent to install a new starter motor. I'll shit a brick if I do that and a newly bought starter does the same thing (intermittent non-start). Keep in mind I can no longer DIY. Lack of place to do it, lack of jacks, etc.
    Just curious...if a new starter motor needs to be returned, what are the symptoms of that? Does it just refuse to crank? Does it crank weak? Does it intermittently not work but sometimes does? Also if I may...what are the opinions here about buying a refurbished starter? A dice roll just like anything else?
  3. Apr 10, 2020 at 3:24 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I’ve bought rebuilt starters before and had decent luck with them. If it’s pretty simple to change you can try one. If it’s a bear to change buy a new brand name one.
  4. Apr 10, 2020 at 4:35 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    That can go the other way in the last few years I had so many bad reman starters and alternators I now buy the rebuilt ones from my dealer.
    OP ask the shop doing the work what there policy is replacing rebuilt starters that fail most all will charge removal and install labor again that is seldom covered by the parts vendor or rebuilder so know going in.
    Best ofLuck
