Starter noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hucker, Jan 27, 2009.
  1. Jan 27, 2009 at 10:01 PM
    hucker
    hucker [OP] Member
    boise
    2000 PreRunner
    Big air repair custom bumper Magnaflow cat back Airraid Spacer Spectre intake Hood Spikes
    Hey, my starter is making a bad noise when I start the engine. Once the engine fires it makes a sort of grating noise. My guess is that it's not retracting as quick as it should. I need to do something quick so I don't trash my flywheel. If I pull the starter off is there something I could clean and/or grease so that it fixes the problem? Starter is on a 2000 pre-runner
  2. Jan 27, 2009 at 10:08 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    You can try to clean up the solenoid, But it sounds like the starter is going south, check out the local parts store, price might not be that bad to just replace
  3. Jan 16, 2018 at 8:07 PM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Mines doing this now.... What was the issue
  4. Jan 17, 2018 at 12:09 PM
    ThunderOne
    ThunderOne I was here before your Tacoma was even born
    Mitchell
    Nashville, TN
    1ST GEN OR GTFO
    lol
