Starter or fuel pump on its way out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeffafitz, Aug 18, 2021.
  1. Aug 18, 2021 at 10:16 AM
    jeffafitz
    jeffafitz [OP] Obviously, You're Not A Golfer.
    Jeff
    Northern Kentucky
    2013 TRD Sport 4x4 DCLB
    This morning I cold-started my truck and took it a mile up the road to the convenience store. Grabbed something, came back out to leave less than five minutes later, truck wouldn’t start. It was cranking fine, lights and electronics were all functional, engine just wouldn’t fire. I turned it off and sat for a few minutes before trying again. Fired right up.
    Which is most likely on its way out? Starter or fuel pump? Perhaps just a one-off occurrence?
    I know this isn’t much to go off of. Just trying to stay in front of the 8 ball if I can.
  2. Aug 18, 2021 at 10:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds like contacts or wires in the starter.
  3. Aug 18, 2021 at 11:10 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    You said it was cranking fine, just wouldn't turn over. Right of the bat that's confusing. Maybe you mean it wouldn't fire?
    SR-71A and RedWings44 like this.
  4. Aug 18, 2021 at 11:13 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    If by "turn over" you mean it wouldn't fire off but was cranking then your starter isn't the issue.
    SR-71A likes this.
  5. Aug 18, 2021 at 1:42 PM
    jeffafitz
    Jeff
    Northern Kentucky
    Sorry, yes, by “turn over” I meant fire.
  6. Aug 18, 2021 at 1:58 PM
    jeffafitz
    Jeff
    Northern Kentucky
    I just went out to my driveway to try to start it again. Back to no fire, but turning over.
  7. Aug 18, 2021 at 3:00 PM
    Taniwha
    Taniwha Well-Known Member
    Dave
    Kamloops, B.C.
    2009 Taco 4cyl. 5 speed 4x4 Speedway Blue
    This is worth looking into. Really sent me for a loop. It was the chip in my key that was not telling the immobilizer that it was a registered key. The valet key does the same thing. Turns over but won't fire. I won't bore you with the details, but after alot of greif, on a wim, I tried my spare chip key. Haven't had a problem since. Easy to check. Cheers, Dave
    Marc70 likes this.
  8. Aug 18, 2021 at 3:01 PM
    jeffafitz
    Jeff
    Northern Kentucky
    Unfortunately I only have one key.
  9. Aug 18, 2021 at 4:25 PM
    RedWings44
    Michigan
    I'd say it's a pretty safe bet you're not getting fuel. Any codes or recent work?
    ToyoTaco25 and Torspd like this.
  10. Aug 18, 2021 at 4:27 PM
    jeffafitz
    Jeff
    Northern Kentucky
    No codes. New spark plugs about 2k miles ago.
  11. Aug 18, 2021 at 4:37 PM
    RedWings44
    Michigan
    How many miles?
  12. Aug 18, 2021 at 4:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Intermittent problems are the worst to diagnose but definitely not a starter if the engine is turning over normally but not firing.
    If you have no flashing key light in the center of the dash with the key inserted it's most likely not an immobiliser issue.
    You would need a fuel pressure gauge hooked up when it acts up to verify fuel pressure.
  13. Aug 18, 2021 at 4:42 PM
    jeffafitz
    Jeff
    Northern Kentucky
    167k miles.
    I don’t hear the fuel pump when I turn the key on. Should hear it, right?
  14. Aug 18, 2021 at 4:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Try another battery
  15. Aug 18, 2021 at 4:44 PM
    MGMDesertTaco
    Sounds like the fuel pump is dead. You might check fuses just to be sure.
  16. Aug 18, 2021 at 4:45 PM
    jeffafitz
    Jeff
    Northern Kentucky
    Checked fuses, they’re good. Won’t jump start either.
  17. Aug 18, 2021 at 4:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No, the fuel pump on 2nd gens only runs when the engine is cranking or running, there is no "key on prime" like there is on other vehicles.
    SR-71A likes this.
  18. Aug 18, 2021 at 4:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Will it run on carb cleaner?
  19. Aug 18, 2021 at 4:46 PM
    RedWings44
    Michigan
    A battery wouldn't be the issue if it is cranking
    ToyoTaco25 likes this.
  20. Aug 18, 2021 at 4:47 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You could also have someone beat on the fuel tank while your cranking, if it takes off you need a fuel pump.
    b_r_o, wilcam47 and RedWings44 like this.
