Starter or ignition problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tonyt915, Jun 1, 2014.
  1. Jun 1, 2014 at 6:45 AM
    tonyt915
    tonyt915 [OP] Well-Known Member
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Pelfreybilt front bumper, SOS skis plates and rear bumper, Icon extended travel coilovers, Icon 2.5 w/resi's rear shocks, Dakar lead springs, Warn 9.5ti winch, Oem roofr rack
    Still new here and did a search but could find any info, but I went to start my truck this morning and when I turned the key I could hear the starter engage but didn't try to start the motor. Tried a couple of times then finally the motor started turning but didn't fire up for a couple seconds while it was spinning. Went to the store about 10 min down the road and it did the same thing about not turning over but this time after a few turns of the key it turned over and fired up right off the bat. So I get back home and unload but grabbed the spare key to move the truck since the main one is was on the other side of the house. Put the key in and it fires up first turn. Turned the truck off and tried it about 5 more times without a problem. Went back inside to grab the main key I use and it started up without a problem. Also just a back history this problem started yesterday but wasn't as bad, and when I used the spare key I didn't seem to have any problems. Not sure if it was just a coincidence that when I use the spare key I don't have problems starting such as when I use the main key first and it doesn't want to start.
  2. Jun 1, 2014 at 6:59 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Use your spare key for a few days and see if the problem still occurs. Could be the microchip in your main key deteriorating, but it's rare.
    I had a similar problem with a Dodge Caravan years ago and had to call a tow truck. The tow truck driver turned the key back and forth about 15 times; eventually the starter moved and started the engine. The van didn't have modern immobilizers, chipped keys, alarms, etc. The starter was replaced.
    Manfred likes this.
  3. Jun 1, 2014 at 7:03 AM
    tonyt915
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Yeah, I was going to start using the spare but would like to have a starter on the way if that's the problem.
  4. Jun 1, 2014 at 8:28 AM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    If you turned the key and heard it engage then it either didn't fully engage or there is missing teeth on the flywheel.
    Sounds like it's not fully engaging tho'.
    You could take it off and have it checked or like the fellow says it might be the fob.
  5. Jun 1, 2014 at 8:33 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd buy a new battery.
  6. Jun 1, 2014 at 8:41 AM
    NWOffroad
    NWOffroad Active Member
    Hippieville OR
    09 DCLB 4x4 LT
    TC LT, Kings, DMZ, Rigids, a few other goodies...
    Check your electrical commection,specifically your battery and chassis ground. Often what happens is corrosion build up not allowing full current to reach the starter motor. There is enough current to engage but not turn the motor. After a few tries it may arc inside the connection and clear up a bit. Best thing to do is clean the battery terminals and ground wire connection. I am a fan of those felt terminal protectors and/or red terminal spray.
    As for the not starting while engine turning over, during the initial attempts and the engine not rotating, the injectors were delivering fuel. Sort of a hot / rich start condition.
  7. Jun 1, 2014 at 10:40 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Figure the battery is nearly 5 years old; gotta replace that first. You're south of Houston? Figure the heat would halve the life of a 84 month battery and may have weakness in the cells hit/miss on connections.
    SHouldn't be your key though.
  8. Jun 1, 2014 at 11:39 AM
    gearcruncher
    Canadain bumper technician
  9. Jun 1, 2014 at 11:41 AM
    wgreenlee1021
  10. Jun 3, 2014 at 4:45 AM
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    '22 TRD Pro Taco; 6MT
  11. Jun 3, 2014 at 5:04 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Yea, I had to change mine out last year and it sucked dude. Bolts were on there right, had to heat them up, take off linkage and steering shaft to get to it as well. PITA. Haven't had problems since with my AutoZone starter (knock on wood)
  12. Jun 3, 2014 at 9:27 AM
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    Had to heat up which bolts? For the exhaust?
  13. Jun 4, 2014 at 9:48 AM
    tonyt915
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Sorry for the late reply, Battery is an Optima yellow top from 10/12 so not the original battery. Been switching the keys back and forth and havent had a problem since. Not sure why I had problems for those two days
  14. Jun 4, 2014 at 12:06 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    No on the starter. Even the impact couldn't get them off.
  15. Jun 5, 2014 at 7:31 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    IMHO, very common Toyota starter problems are burned starter solenoid contacts, corroded battery power or ground connections, unhealthy battery, or worn starter brushes, in that order. But, since you live in a hot climate, check your electrolyte levels (and add distilled water, if required), fully charge your battery, and have it tested. Most auto parts and battery stores will do this free and it only takes a few minutes. For more information, see Car and Deep Battery FAQ on www.batteryfaq.org.
  16. Oct 12, 2014 at 1:34 PM
    Shamal
    Shamal Active Member
    BC
    SR5 4X4
    My 2008 starter was beginning to act up, removed and rebuilt it, but felt some updates to this site might be in order.
    If you have a 4X4, this is NOT an easy task. The explanations here are not easy to follow, and I appreciated the factory manual links, but I don't know how one could follow the directions to remove the starter on this site, as i read whatever i could find is posted.
    Here's how I did it:
    The starter is unbolted and then taken apart while still in the truck, to remove it without taking the exhaust or drive train apart, removing a steering linkage rod, or bending the brake lines.
    The 2 bolts holding the starter to the engine are extremely tight, and require a 1/2" drive extension set, 3/8" will bend and spring. You need a long extension to reach up in there from under the truck, and a universal fitting, and a good quality, tight fitting 6 point socket.
    Crack the 2 bolts by hand using the 1/2 " drive set, and then they come out easy with your air ratchet, or by hand.
    There are 2 bolts that hold the the starter to the yolk, remove these to pull the yolk from the starter. Be Careful! The starter has nothing holding it together, best done with a friend to hold while you undo the bolts from underneath, and the yolk is facing up.
    Now the motor comes down easy through the frame, but the yolk must be removed by getting directly under the opening between the axle and frame, and if you carefully place the yolk horizontally, you will see they designed it to come out and go back in that way, and ONLY one way.
    I took my starter apart, thanks to the excellent diagrams supplied in the links above, and found it in near perfect condition save for the solenoid and copper contacts. I bought a replacement kit from my local rebuilder ( $20) and they showed me how to press the solenoid in place ( I used my drill press) while tightening the copper contact, to get them in Exactly the right place. The main mistake they see is not doing this, and the copper contacts wear out sooner than they would otherwise.
    I cleaned and re-greased the gears, polished the motor and put everything back together. My brushes were is excellent condition, all gears perfect.
    Re-install is the reverse of what I have explained, having a friend hold the yolk while you feed the motor assembly carefully up through the space while holding the parts together, slip the 2 bolts in and start them to hold the assembly together. Tighten them up and the the starter goes back in place. I did not over-tighten like the factory did, just about 65lbs of torque.
    The starter worked like the truck was new, I did not realize it has been slowing down a bit over the years. It is a real shame to think these quality pieces of equipment are being thrown out, because the cost and time to rebuild then is excessive at dealer rates.
    I hope this helps explain and make someone's work a little easier.
  17. Oct 12, 2014 at 1:48 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    Before removing clean the conections the try and start one more time.
    HBMurphy likes this.
  18. Sep 23, 2015 at 10:45 AM
    Manwithoutaplan
    ID
    sub'd i think my starter just took a crap and it making me throw a code p0345.
  19. Sep 17, 2020 at 9:11 PM
    AAlexander
    AAlexander Member
    Reading this, I have to wonder if there are significant differences in that area within the Gen2. I just got finished pulling the starter on my 2013 4x4 4 cyl manual trans. Your description of loosening the mounting bolts is right on, but based on this and some videos I'd watched, I was expecting to have to struggle to get the starter out, disassemble it, take extra parts off, etc. Once I got the starter off, I was able to remove it down between the frame and engine without any problem.
    hresendiz25 likes this.
  20. Sep 17, 2020 at 11:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    He probably has a V6 1GR-FE Engine which would have an exhaust header pipe in the way where your exhaust is on the opposite side with a 2TR-FE 4 Cylinder.
    AAlexander[QUOTED] likes this.
