Starter or solenoid ?... not battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dborrer, Nov 25, 2023.
  1. Nov 25, 2023 at 10:31 AM
    dborrer
    dborrer [OP] Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    Went to start up the truck today, and heard a sound, sort of a pop and nothing. No electronics on the dash or anywhere, did not even begin to crank.
    I pulled the battery and went to AutoZone, tested as Good, plenty of cranking amps... it is a 2019 battery.
    So without any other info, am I looking at a Starter or solenoid issue? I'll go look at fuses maybe but....
    I'm still with the original of both (Starter & solenoid), 262k miles and counting... (Manual Transmission, V6)
    Thanks in advance for any input, advise or recommendations...
  2. Nov 25, 2023 at 10:34 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Did you try push clutch cancel button?
  3. Nov 25, 2023 at 10:35 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Sounds like bad ground if you heard pop and dash lights went black.
    dborrer[OP] likes this.
  4. Nov 25, 2023 at 10:52 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    If its just a hard click it could be the contacts in the started also.
  5. Nov 25, 2023 at 10:59 AM
    dborrer
    Mr. Dan
    St. Augustine, FL
    I just put the battery back in, and with the door open, key put in - the door ajar light came on, I turned the key and she fired up as normal... SO WTF ??
    I've not really done anything under the hood lately... is it possible that somehow I didn't have tightened down enough the battery terminal cable themselves at the battery post? A yearish ago I added the Headlight relay kit, with upgraded headlight bulbs... so maybe something was working lose since then...?
  6. Nov 25, 2023 at 11:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Probably was a bad connection on one of the battery cables and moving things around taking the battery out fixed it.
    b_r_o, Bishop84 and dborrer[OP] like this.
  7. Nov 25, 2023 at 11:46 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    After a zillion years of experience when ever I have what I think is a starter/solenoid problem the first thing I do is check the battery itself and battery connections to be sure they are tight and free of corrosion. Then I check the other connection's to the starter/solenoid to check they are tight and free of corrosion. Especially pay attention to grounds. I’ve found the majority of times ive had electrical problems of any kind it turns out to be a ground problem. I’ve known a number of guys that have replaced a solenoid or starter and then they discovered it was electrical/wiring/poor connections.
    dborrer[OP] and Clearwater Bill like this.
  8. Nov 25, 2023 at 11:54 AM
    IvanhoeTaco
    Eastern NC
    When you heard the pop, that was an arc from the loose connection. It probably sounded like an electrical snap and not a solenoid click. Desd giveaway is dash went black with key on
  9. Nov 26, 2023 at 5:27 AM
    dborrer
    Mr. Dan
    St. Augustine, FL
    yesSir @IvanhoeTaco now that you've stated the above, I think that is exactly what sound I heard. And I think that was my first time experiencing it (that event and that sound).
    And thank you @Sprig for your comments... looks like that is exactly what happened, possibly my + post connection...
    All of that said, i've been contemplating lately (since I'd replaced OEM housings and upgraded light bulbs) of upgrading "the big 3" or is it 5? wires and terminal post connectors... Anyone want to make some recommendations?
    I have read a bunch of the threads on TacomaWorld... just haven't made any decisions .... but something is telling me now is the time.
    Sprig likes this.
  10. Nov 26, 2023 at 8:16 AM
    Waasheem
    Waasheem
    2007 xrunner
    I made a mistake a couple times. I had a car with an intermittent no start no crank. I bought everything to replace the starter and upgrade the battery cables and terminals. During disassembly I found the positive battery cable attached to the starter loose. Another was an alternator not charging. Got a replacement, found one of the wires on the connector mostly broken barely hanging on.
    There’s multiple options from very cheap crap to very expensive. Just don’t use the temporary field repair type. They tend to work themselves loose. There’s military style which are nice. Makes adding on cables easy.
    dborrer[QUOTED][OP] likes this.
