starter problems?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tlh178, Feb 11, 2016.
  1. Feb 11, 2016 at 2:09 PM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    looking for ideas on starter! my son put a new starter, new battery cables and replaced starter relay fuse. plus new battery! his taco would not turn over, so he brought a new battery and drove it for three days and now it won't start again. just to make sure it wasn't the new battery, his friend put his battery in there and no luck. he lives an hour away and i'm going down tomorrow to tow it back to my house. my thoughts are maybe neutral safety switch or ignition switch and maybe alternator. do you guys have any thoughts on what may be the problem? thanks in advance for any help! its an 02 prerunner w/ a 3.4L! 2wd!
  2. Feb 11, 2016 at 4:46 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Can you jump it off at all? If you can get it running hook a volt meter up and see what voltage its pushing. I am sure many more will chime in to help ya more than I can
  3. Feb 11, 2016 at 4:48 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Auto trans?
  4. Feb 11, 2016 at 5:00 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    If a brand new battery dies in 3 days, I would say the Alternator. But....I would 1st check the wires to the starter and the ground wires to be sure. Putting your friends battery in and it still not starting has me a bit baffled. Something is not connected correctly.
  5. Feb 12, 2016 at 3:43 AM
    tlh178
    terry
    lake huron/sag bay
    thanks guys, my son called last nite and said its starting now. i guess i'm safe for now! good thing, its 0 degrees here this morning!
  6. Feb 12, 2016 at 12:51 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If the starter he got was aftermarket, it might not be cold weather rated. I always recommend getting the cold weather rated starters, no matter what. It puts out a little more power.
