Starter R/R for 2008 v-6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calledin, Dec 5, 2011.
  1. Dec 5, 2011 at 2:36 PM
    calledin
    calledin [OP] Well-Known Member
    Mark
    Knoxville, TN
    2008 DC Sport SR5 4x4
    Turned key other day and cranked slow then "click.click, click"! jumped it off. went by parts store and they checked the batt. and alt. ,, all good! said it may be starter going out? 50,000 miles. anyone ever put one on? I searched the site for anything about 08 starter came up empty?
  2. Dec 5, 2011 at 2:40 PM
    calledin
    Mark
    Knoxville, TN
    turned key and got slow turnover and the click click click. parts store checked batt,, ok checked gen. ok.. said starters where bad to go bad on these? Any help??
  3. Dec 5, 2011 at 2:44 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    not sure about 08 starter--BUT previous year starters--EASY FIX--Contacts get worn out--and are easy to replace. any starter/alt shop will have parts.
    As long as you are removing--it an easy check. AND CHEAPER than a replacement.
  4. Dec 5, 2011 at 2:45 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    When I got my starter replaced they took off the driver side suspension to get to it.
  5. Dec 5, 2011 at 2:46 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    if it was cranking it doesnt sound like the starter????????
  6. Dec 5, 2011 at 2:51 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Slow crank does sound like battery or cables--check the connections--most likely need to be cleaned--do the EASY STUFF first.
    Clean batt posts and batt connections. make sure they are tight.
    08 should not have starter problems--YET
  7. Dec 5, 2011 at 2:55 PM
    calledin
    Mark
    Knoxville, TN
    will do ,,,, i'll check everything out first. just wondering if bushing gone bad. it sounded like a sticky starter. hadn't done it again sense? thanks !!!
  8. Dec 5, 2011 at 2:57 PM
    calledin
    Mark
    Knoxville, TN
    sorry posted twice
  9. Dec 5, 2011 at 2:58 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    yeah im not thinkin its a starter man....
  10. Dec 5, 2011 at 3:01 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    HEY you are in Knoxville!!--I am in Pigeon forge!!!!
    Good luck--If you cannot find problem Give me a call.
    Sending a PM w/ PHONE
  11. Dec 5, 2011 at 5:43 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If it's the original battery I would lean towards the battery even if they tested it. Did they actually test the battery under a load?
  12. Dec 6, 2011 at 6:38 AM
    calledin
    Mark
    Knoxville, TN
    Yeah, thay load tested the batt. showed all good. its the orig. batt. as the trucks a 2008. It did start right up when we put jumper cables on it. im gonna watch it for a little while see if it does it again? We even turn the head lights on when it wouldnt start and thay where bright. :confused:
