starter removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, Oct 3, 2008.
  1. Oct 3, 2008 at 8:34 PM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    is a pain in the ass does anyone have any tips on the 2.7 liter i mnaged to get the first bolt out but the top bolt is a pain in the ass any help would be great i have a click when it trys to crank so i do think it is a solenoid or something any help would be great thanks
  2. Oct 3, 2008 at 10:11 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    IIRC, you'll have to undo part of the exhaust to get the rest of the starter out.
  3. Oct 4, 2008 at 10:16 AM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    the egr line maybe because the exhaust is on the opposite side
  4. Oct 4, 2008 at 7:42 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    ummm..take the drivers side tire off...remove the rubber flap that the factory puts there...and unbolt the starter take it out through the wheel well...super easy I did this is the parking lot of auto zone one night so they wouldn't charge me a core charge on a new starter....to top things off the truck was running so i could drive home (they had to order starter)
  5. Oct 4, 2008 at 10:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you sure its no the battery that is the problem?
  6. Oct 5, 2008 at 10:42 AM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    batery is only a year old i do know that when the truck is off i have ahumming coming out of the vaccum box right behind the battery it may be draining it
  7. Oct 5, 2008 at 3:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You may want to start there before jumping in and changeing out the starter.
  8. Oct 5, 2008 at 3:48 PM
    350TacoZilla
    Hancock MD
    I had that humming noise for about 3 years... even if you take the battery out it still does it
  9. Oct 5, 2008 at 6:56 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    what is that humming noise did you find out
  10. Oct 5, 2008 at 7:03 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Have you tried hitting the solenoid with a hammer or punch? If it's jammed up and you knock it loose, it might just be a one time thing.
  11. Oct 5, 2008 at 7:08 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    read this then read your sig line...too funny!
    also too correct. heck of a lot easier to start with a weak battery test than go after a starter.
  12. Oct 5, 2008 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, well....sometimes the simplest soloutions are.........welll............correct. :D
