Starter squealing for one second or less on startup.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by James M. Y., Jun 21, 2025.
  1. Jun 21, 2025 at 6:26 AM
    James M. Y.
    James M. Y. [OP] New Member
    2015 Tacoma
    I am getting a very loud squealing for one second or less on start up. It is longer on the first start of the day. It is like the bendix (starter) gear is not disingaging when the engine starts. I have changed the starter but the noise remains. On-line searches indicated a possible cracked flex plate. I do not see any cracks in my flex plate for what I can see through the opening where the starter goes.
    Any help will be appreciated. Jim
  2. Jun 21, 2025 at 6:29 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    did you replace with an oem starter?
    use a stethoscope & isolate?
    did you inspect the teeth on the ring gear?
    all the teeth by having someone rotate the crank for you, or pushing on the teeth with a pryer & rotating the engine clockwise...
    did the noise change at all after replacing the starter?
    you have more work to do, we cant parts cannon it for you....
    Phlogiston likes this.
  3. Jun 21, 2025 at 10:18 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    It sounds like you need to pull the starter. Milage/year?
    Tacoma is usually bulletproof, if you need to replace you should go with OEM. Cost more but likely last.
  4. Jun 21, 2025 at 10:19 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  5. Jun 21, 2025 at 10:48 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Might be as simple as an old serpentine belt that is slipping and needs replacing.
    Chew likes this.
