starting install of Old Man EMU dakar Leaf packs
Discussion in 'Suspension' started by 907taco, Aug 7, 2010.
  1. Aug 8, 2010 at 5:51 AM
    Sprink669
    Sprink669 Well-Known Member
    Did you reuse the factory leaf spring bushings? I have the same leaf pack and I see that you are missing one of the bushings as I am too. I just never remember seeing the bushings packed in a separate bag. The one side of the leaf pack already has the bushings installed and I just thought I will have to reuse the factory ones?
  2. Aug 8, 2010 at 6:15 AM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Are these supposed to have better ride quality than if you were to AAL?
  3. Aug 8, 2010 at 7:06 PM
    907taco
    907taco [OP] Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    yes i had a revtec 1.5 in. aal, ride qaulity is noticeably better.
    smoother is the best way to describe it.
    the packs came with some red bushings, the rear of the packs already come installed. i ordered the ultimate kit and everything included in the kit from toytec...
  4. Aug 8, 2010 at 7:09 PM
    Chad
    Chad
    Cary, NC
    So would $450 or however much it costs be justifiable?
  5. Aug 9, 2010 at 9:33 PM
    907taco
    Bobby
    Alaska
    IMO yes, but most just get a aal and functions just fine, difference is flex and load capacity in the bed, someone will correct me if i'm wrong.
  6. Feb 27, 2011 at 7:25 AM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    did you disconnect the brake lines, or just follow the instructions of the add a leaf sticky?
  7. Feb 27, 2011 at 9:16 AM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    I did not disconnect the brake lines when I installed my Dakar's. But you will have the lines stretched to the limit to get the drivers side leaf pack in. After the leafs are in the lines are long enough for all but extreme off roading. I have thought about just trying to put a spacer under the brake line bracket connection to the axle in order to gain some slack rather than installing longer lines.
  8. Feb 27, 2011 at 10:21 AM
    ink junky
    TACO LOVER
    TEXAS
    You mean at full flex of the rear?
  9. Feb 27, 2011 at 10:24 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    not so sure dakars are gonna flex all that much if even more than stock
    my stock are like rubber bands compared to these
  10. Feb 27, 2011 at 4:48 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    I think so. Seems like you would have to put the passenger side leaf in full compresion and have the drivers side almost dangling in mid air before the lines would be in danger. But like I said before I think you could gain some slack by modifing (lifting) the brake line bracket at the axle. That would save the $65 and installation, bleeding of new brake lines.
  11. Feb 27, 2011 at 4:50 PM
    Valley Viking
    Menlo, WA
    05 4x4 DC LB SR5
    The bracket mod is something I have on my list of things to check out when the Warden gives me a chance.
  12. Nov 3, 2011 at 7:02 AM
    2011TACOMAWHR
    2011TACOMAWHR TACOMA 2011
    aaron
    lancaster SC
    2011 OR dbcb shortie
    big tires and tiny rims
    Wish me luck im putting mine on right now
  13. Nov 3, 2011 at 7:23 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Luck
  14. Nov 3, 2011 at 9:20 AM
    2011TACOMAWHR
    aaron
    lancaster SC
    Done in two hours booh ya
  15. Nov 3, 2011 at 9:20 AM
    #35
    2011TACOMAWHR
    aaron
    lancaster SC
    With no help
  16. Nov 3, 2011 at 10:03 AM
    #36
    OZ-T
    Peter North
    British Columbia
    Did you install centre pin collars ?
  17. Nov 3, 2011 at 12:58 PM
    #37
    2011TACOMAWHR
    aaron
    lancaster SC
    Ok i used the 3 degree shims i measured with tires on and was 39.5 with a 1.5 inch block. Im now sitting at 42 after a test drive so thats almost 5 inches of lift in the rear over stock
  18. Sep 15, 2013 at 5:38 AM
    #38
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
  19. Mar 11, 2014 at 11:47 AM
    #39
    LowerBost
    LowerBost Well-Known Member
    Nick
    Pittsburgh, PA
    09 Tacoma Sport
    Old Man Emu Lift w/ Dakars and Billsteins, K&N Intake, Throttle Body Space, Front Bull Bar, Side Rails, Painted Stock Rims, Bilstein 5100 Front Shocks, Third Brake Light Cover, Satoshi Grill Mod, BHLM Mod
    Revive! How hard are the shims to put in after the install if I Do decide I need them? I don't want to put them in if I don't.
  20. Mar 11, 2014 at 11:55 AM
    #40
    OZ-T
    Peter North
    British Columbia
    Did you use centre pin collars ?
