Starting issue 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jtaoj0, Mar 29, 2015.
  1. Mar 29, 2015 at 12:23 PM
    Jtaoj0
    Jtaoj0 [OP] Well-Known Member
    high starting to post more after having my 2015 v6 DCSB OR 6 weeks. More questions on the quirks. My truck turns over fine but doesn't catch immediately. If I stop turning over and try again it fires right up. Not all of the time but often. Anyone experience similar? Tx in advance.
  2. Mar 29, 2015 at 12:27 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Yep...same issue. Happens 80% of startups....at least.
  3. Mar 29, 2015 at 12:38 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Take it to the dealership. Don't try fixing it yourself.
  4. Mar 29, 2015 at 12:45 PM
    Tacoma Mike
    Southern Maine
    The truck has a procedure it needs to go through before starting. You can't hurry the procedure. I doubt very much there is an issue. Turn the key on and wait a moment for the ecu to get it's inputs before cranking.
    Mine has extended cranks on occasion.
    If I was worried about it............
  5. Mar 29, 2015 at 1:20 PM
    Idaholandho
    Ummm no. The procedure does not include wearing the starter out. And, I can leave the key on, sit and reflect how much a piece of shit the worthless Entune is, power scratch my balls, put my clothes back on and I have the same issue.
  6. Mar 29, 2015 at 1:29 PM
    Tacoma Mike
    Southern Maine
    We are interpreting his post different.
  7. Mar 29, 2015 at 2:18 PM
    Idaholandho
    May of been my sarcasm :notsure:.
    But, I think I understand it completely. Key in, turn key, starter turns over(for as long as you want to sit there and listen to it), turn key off, and back on to start and it fires right up.
    He and I have similar issues with our 2015's. My 2011 did not have this issue. Not even close.
  8. Mar 29, 2015 at 2:50 PM
    Tacoma Mike
    Southern Maine
    His word immediately is what I focused on.
    If he has a long crank. Ie more than 3 seconds then by all means it should be checked. I was told by higher ups 2 seconds was not unusual due to the procedure being involved with the timing sensing check. Just relaying stuff.
    Oh you might want to get some ointment. That scratchy ball symtom sounds nasty.. Lol.
  9. Mar 29, 2015 at 2:58 PM
    Jtaoj0
    Hi it starts pretty much like this but I haven't waited as long to do all of those activities:)
  10. Mar 29, 2015 at 5:22 PM
    spp
    spp OC, Kalifornia
    OC California
    :eek:
  11. Mar 29, 2015 at 6:05 PM
    Tacoma Mike
    Southern Maine
    Well played sir.
  12. Mar 29, 2015 at 6:09 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    haha you guys are nuts :laughing:
  13. Mar 29, 2015 at 7:05 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    These trucks have had issues similar to what your experiencing since at least 2007. I've read of it year after year here... not sure what the fix is nowdays. Happened to me two weeks after buying mine back in 07. They had a intermittant no-start tsb for the issue... never had the problem since.
  14. Mar 29, 2015 at 8:16 PM
    Jtaoj0
    So you had the TSB done? If so do you recall the details? Thanks.
  15. Mar 30, 2015 at 6:42 PM
    OffroadToy
    Yep... got the work order right here. Had the truck for 2 weeks and had 166 miles on it. The TSB was EG011-07 for intermittant no-start condition... wouldn't start on first crank. The TSB recalibrated the ECM to correct problem. OP CODE EG5054 T1-01 T2-99 (not sure what those numbers mean.) After having the tsb done i've never had a problem since. From the posts i've read here alot of these trucks have had intermittant no start issues for at least 7 years.
    To those that say you have to hold the key and wait before cranking i don't have to do that. After the tsb... insert key, turn, truck starts on first crank... every time.
  16. Mar 30, 2015 at 7:28 PM
    Jtaoj0
    Thanks! Awesome info. I appreciate all of the help!
