Starting Issue (alternator?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacoma4x4, Feb 24, 2011.
  1. Feb 24, 2011 at 10:51 PM
    1998tacoma4x4
    1998tacoma4x4 [OP] Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    So i drove my truck home from the store without any problems, went inside and unloaded the groceries, grabbed a jacket and headed back out. When i went to restart my truck it clicked loudly once and then nothing. The battery is newer, about 2 years old. What could cause it to be running perfect one second and then die completely?? The battery terminals are clean and connected too.
  2. Feb 24, 2011 at 11:41 PM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    Solenoid going bad is the most likely culprit. It will start having problems when hot. Sometimes you can tap on the starter with a hammer to get the solenoid to engage.
    You may get lucky and have a loose wire at the starter....so check all starter related wiring for good connection. If all connections are good then it's prolly the solenoid.
    In that case you just would replace the starter & solenoid together since it is attached.
  3. Feb 24, 2011 at 11:52 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    I may have misread what your asking....are you saying everything is dead as in no power at all or just the starter??
  4. Feb 25, 2011 at 10:57 AM
    1998tacoma4x4
    Orange County
    I'm gonna look like a huge idiot but it was the positive battery terminal. it was dark when i was looking under the hood last night but when the sun came out this morning i looked again and the terminal was really loose for some reason. I tried tightening it down but it just bent it out of shape so im getting a new one from autozone. Thanks for the help though!!
