Starting Issue...
Discussion in '1st Gen. Tacomas (1995-2004)' started by TRDBen, May 28, 2011.
  1. May 28, 2011 at 1:52 PM
    TRDBen
    TRDBen [OP] Mall Crawler of the Year
    Ben
    San Luis Obispo, CA
    02 Prerunner 4 Door TRD V6
    Front Window Tint KYB Monomax Shocks Blue Dome Light Valentine 1 Radar Detector
    Whenever I go out and start up my truck after shes been sitting over night and go to start her up, theres an initial hesitation (lights come on but no cranking). Then she slowly cranks and fires right up. My battery was just replaced in December so Im clueless as to what the issue is. I just took her offroading so my dad thinks that has something to do with it. Any ideas?
  2. May 28, 2011 at 2:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I had an 02 that had similar issues but it was sparatic, the largest issue was it starting and having crazy rpm until I revved the engine. It would never do it at the dealership.....of course so I lived with it for a while ended up being my idle sensor. You didn't mention issues with idling but mine started out simple with slow starts, and dimming of the lights. I replaced and charged the battery to no avail then it progressivly got worse and I ended up having it not start for a Tech at the dealership so he changed the idle sensor. Truck ran fine after that.
  3. May 28, 2011 at 3:30 PM
    TRDBen
    Ben
    San Luis Obispo, CA
    Mine idles great. Its just these weird cold start ups that are bugging the shit out of me.
  4. May 28, 2011 at 5:27 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Your starter solenoid is the most likely suspect. Check all of your battery cable connections for corrosion and torque, starter included.
    Have your charging system tested at autozone too.
  5. May 29, 2011 at 12:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Does it click before it finally starts? if so its that starter or starter solinoid. Thats what happened to my truck.
    Also as stated before test your battery just in case. Once my battery was fully charged but only have 2.1v in it so there was no way in hell it would start lol
