Starting issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma530, May 8, 2017.
  1. May 8, 2017 at 7:33 PM
    Tacoma530
    Tacoma530 [OP] Well-Known Member
    Devin
    Anderson
    white 1997 tacoma 2.7 (3rz) stock
    All stock
    I have a 1997 Toyota Tacoma 2.7 4x4
    Did a full rebuild on motor
    Tried starting it , seen spark down by the starter , heard the clicking sound from the starter I believe trying to start . purchased a new battery then a starter. Still wouldn't start heard same clicking didn't change anything now no clicking. Could this be bad wires to the starter from the fuse box?
    Or starter relay?
    Need help
  2. May 8, 2017 at 9:30 PM
    Glamisman
    Glamisman Well-Known Member
    verify that the ground wires on the block, from firewall to cylinder head and negative cable to chassis are tight.
    cruiserguy likes this.
  3. May 8, 2017 at 9:36 PM
    Tacoma530
    Devin
    Anderson
    All stock
    Ok thank you. I'll check that tomorrow
  4. May 9, 2017 at 12:12 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Also verify you have 12 volts at the big starter post. Just had one today that the cable had acid rotted in the middle. Right under the crank pulley.
  5. May 9, 2017 at 4:04 AM
    Tacoma530
    Devin
    Anderson
    All stock
    Ok will do
  6. May 9, 2017 at 9:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    when you say you saw spark was that on a meter or an actual spark? If its an actual spark something is loose and or not making contact or not connected.
    outlawtacoma likes this.
  7. May 9, 2017 at 7:36 PM
    Tacoma530
    Devin
    Anderson
    All stock
    So I figured where the spark was coming from, it the ground wire that is by the starter connector and positive wire. Now my question is. Where does that ground wire go?
  8. May 9, 2017 at 8:01 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  9. May 11, 2017 at 9:01 AM
    wilcam47
    Will
    Bourbon state
    I would guess the wire broke off at the connector on the starter. It should go on the little post if its a smaller gauge wire.
  10. May 11, 2017 at 11:44 AM
    Tacoma530
    Devin
    Anderson
    All stock
    Still intact. I believe we found the issue
  11. May 11, 2017 at 12:04 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    ? What was it?
  12. May 11, 2017 at 2:14 PM
    Tacoma530
    Devin
    Anderson
    All stock
    The ground that's down right by the starter positive and the connector. It was bent around n connected to the engine mount " Buddie fault" it goes to the frame by the starter correct?
  13. May 11, 2017 at 2:16 PM
    Tacoma530
    Devin
    Anderson
    All stock
    Someone who knows these trucks contact me and so we can discuss over phone
  14. May 11, 2017 at 8:20 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    It should go to engine block.
  15. May 11, 2017 at 11:07 PM
    Tacoma530
    Devin
    Anderson
    All stock
    Yeah found that out. Thanks
  16. May 12, 2017 at 12:18 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Did you get it fixed?
  17. May 12, 2017 at 3:18 AM
    Tacoma530
    Devin
    Anderson
    All stock
    Yeah by the time I'm don . I'll have everything new tho lol
  18. May 12, 2017 at 6:57 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Were you ever able to determine the exact problem?
  19. May 13, 2017 at 2:49 AM
    Tacoma530
    Devin
    Anderson
    All stock
    Bad ground, Buddie had the ground attached to the motor mount, smh . Connected to the block under starter.
    Dalandser likes this.
  20. May 13, 2017 at 9:45 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Ahh so the motor mount was insulating the ground from the block.
    Tacoma530[OP] likes this.
