Starting issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mis$I$sippi_hippie228, Aug 25, 2017.
  1. Aug 25, 2017 at 12:33 PM
    Mis$I$sippi_hippie228 [OP] Member
    Waylon
    The Gulf Coast
    99 taco, 98 taco, 03 taco, 98 taco, 95 4runner
    So this is my first thread. Anyhow my I need help I just bought a 99 3.4 auto 4x4 project had a bad front end when I bought it so I have that fixed and now it'll only start when jumped. I know it isn't the battery or dirty terminals. When I turn it over the starter clicks so I pulled it, replaced the contact and plunger. Installed the starter and still just clicks??
  2. Aug 25, 2017 at 12:39 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Does it start with a jump?
  3. Aug 25, 2017 at 3:54 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    If it will start when jumped it sounds like a low or bad battery. Or even dirty terminals.
    lucky13don likes this.
  4. Aug 25, 2017 at 4:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    That makes no sense.
    If it starts jumped it's because of the increased voltage/amps being introduced.
    What is your evidence your installed battery is good?
    mechanicjon likes this.
  5. Aug 26, 2017 at 8:16 AM
    Glamisman
    Glamisman Well-Known Member
    OP... the current has to get to the starter and back to the battery so there could be bad cables/connections at the battery and or bad grounds on the block. If there is crude on the cables at the battery connections you are going to have to replace the cables... electricity flows on the outer surface of the wires so anything that prevents that is no good.
  6. Aug 26, 2017 at 9:00 AM
    FromTejasWithLove
    FromTejasWithLove Well-Known Member
    Cale
    Hurricane, Utah
    '99 Taco SR5 4x4 V6; manual everything
    Turtle Top Shell, Rear Single Motorcycle Carrier, Refrigerator
    +1
  7. Aug 26, 2017 at 2:29 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Look on the bright side, at least you have a nice newly built starter :)
    Use another battery and see what happens - even a battery that has a full charge may not have enough cold cranking amps to run the starter.
  8. Aug 26, 2017 at 5:47 PM
    Waylon
    The Gulf Coast
    Yea I pulled the battery out of a lincoln towncar I have which it cranks it with ease. It doesn't make any sense to me either I'm guessing it has to be a connection issue somewhere maybe a I'm not getting a good ground. The block is grounded to chassis good I have made sure.
  9. Aug 26, 2017 at 6:16 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I'd be looking real close at battery terminals and cable to terminal connections. When you jump start it are you grounding the black jumper cable to the battery or engine somewhere?
  10. Aug 27, 2017 at 7:43 AM
    Waylon
    The Gulf Coast
    Black cable is going to the negative post on the battery I've been tinkering with it for a few days now everything around the battery is cleaned or new
  11. Aug 27, 2017 at 8:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    What doesn't make any sense, at least from what you have written, is why you are adamant that the current battery is good.
    Everything you say points to it being the problem.
    So I'll ask again, as in post 4,
    And even if it should happen to load test good, the next question would be is it the proper size/CCA for the vehicle?
    When something starts with a jump, or another known good battery, that sure seems to leave the issue in the lap of the existing battery.
  12. Aug 27, 2017 at 9:18 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    theres also a ground to the engine block. if thats loose it wont start . but i would bet on battery.
  13. Aug 27, 2017 at 11:32 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    you could also just use a KNOWN,,,, since some people on here like to capitalize to get a point across :anonymous:,,, good jumper cable, temporarily, to connect from known good battery like you said to the starter to take the cable out of the equation,, both pos and grd.
  14. Sep 1, 2017 at 7:54 AM
    Clearwater Bill
    Billy
    Largo Florida
