Starting issues!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fitzy3334, Apr 29, 2011.
  1. Apr 29, 2011 at 3:50 PM
    fitzy3334
    fitzy3334 [OP] New Member
    2011 TRD Off Road
    I just want to get armed with any information before i make an appt with the dealer. bought brand new trd off road. about 8-10 times i would turn the key and i can hear the starter turn, the engine would sometime hesitate to catch and will catch. other times i can hear the starter turn and hear the engine try to catch and wouldnt catch. any ideas why this is going on?
  2. Apr 29, 2011 at 4:02 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the battery is probably bad, go to napa/kraigens/autozone/chevron and get the battery checked
  3. Apr 29, 2011 at 4:03 PM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    That's happened to me twice. I'll try to start the engine and it won't start. I'll wait a few seconds and the truck will start. I have a 2010 with only 9000 miles.
  4. Apr 29, 2011 at 4:06 PM
    fitzy3334
    2011 TRD Off Road
    yeah mine only has 3200. good call i'll have the battery checked. it seems to only happen mid day too after i already drove it
  5. Apr 29, 2011 at 4:12 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    That actually happens with mine about every 40-50 times I start my truck. It has since I have owned it, regardless of the battery life. It did it when my battery was 5 years old and has done it since I replaced it several months ago. Not sure why it does this... Truck runs perfectly otherwise.
  6. Apr 29, 2011 at 4:14 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Insert key, wait two seconds then turn. See if that helps.
  7. Apr 29, 2011 at 9:57 PM
    StaticTaco
    StaticTaco Well-Known Member
    Mitch
    Oahu
    2011 SR5 4WD
    ^ this. Seemed to help mine when t started doing that, just give the comp time to read the key, seems if you just insert and turn too quickly it'll do that false start.
  8. Apr 29, 2011 at 9:59 PM
    toyotatacomaTRD
    Thanks guys. I will give this a try.
  9. Apr 29, 2011 at 9:59 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah, it's a chipped key, so it'll take a little bit of time for your truck to recognize it. Try it out, a 1 - 2 seconds wait won't kill you.
