Starting Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by 73dodge, Jan 17, 2015.
  1. Jan 17, 2015 at 2:15 PM
    73dodge
    73dodge [OP] New Member
    SR5
    I have a 04 Taco with the 2.7L.
    I am having a problem with starting my truck.
    When I start up the truck and say drive a very short distance and shut the truck down. If I try to start it again it will sit and crank and crank and crank and then the engine will sputter to life.
    If I drive it a distance and shut down and restart the truck starts up fine.
    So it has only done this when I run it for a few minutes and shut down, restarting it will be a problem.
    I had the upstream O2 sensor replaced but it had been doing this before I had it replaced. Anyone have this problem?
    I did a forum search and can't find a match so I am hoping someone can tell me what they may know.
    Oh and I am a newbie.... :eek:
  2. Jan 18, 2015 at 6:24 AM
    usptwins
    usptwins Well-Known Member
    Trey
    Louisiana
    Taco SR5 Stock stock stock
    Kyb shocks/struts, Nitto Terra Grappler G2's in 285/70R17.
    I have the same prob. but its when it sits over night. Good luck
  3. Jan 18, 2015 at 6:34 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Engine Coolant Sensor, perhaps.
